Interested in some input on possible causes for a long horizontal crack between the first and second course of bricks. Came across this in a one year old house this week. The pictures do not really show the crack well. House was a slab foundation in sort of a U shape. One side of the U was the garage. The other was a den. In between there was patio. The Den side had some significant movement (from drainage problems I think) that warrant structural engineer input, so I am recommending further investigation anyway. The garage side had the cracking described above. It was present on both sides but worse on the patio side. I am just interested in possible causes for my own education and for the future when I may see something similar in a home that doesn't obviously require a structural engineering evaluation.
Thanks Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Long horizontal crack... did you notice an bowing when looking from a side angle?
No. And the bricks did not seem loose when touched.
I'm missing something here,what pictures are you talking about? 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
The ones that I took but did not post here because the problem is not really visible on them.
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 11:10 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 8:40 AM |
| slab no cracks: Brick veneer cracks | gkoehl | Structural Inspections | 1 | 4/17/07 5:52 PM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 10:20 AM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 7:34 PM |
