The things people do. . .
But is there fire rated drywall on the bottom of the pull down stairs?
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
My question is, WHY? Was all that done to allow installation of the pull down?
Homer goes to sell and some idiot nit-picking home inspector calls out absent/altered trusses, structural engineer, blah blah blah Homer is seething, agents are peeing on themselves, buyer is in a state of utter despair, dream house is going to crumble before the ink is dry. Enter, Super Solutions Homer, he convinces all involved he knows best, can repair in a few hours, no need for SE, some 2x's and a handful of screws, Shazam the deal can progress with no further delays, no harm no foul. Now Jeff comes along starts the whole cycle again...he knows the rest of the story All readers are advised to not take these statements as facts, always consult a professional prior to believing early morning editorials. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 3/9/07 at 5:34 AM.. |
I'm stunned at these alterations. I guess what Barry said is probably true. Makes not a bit of sense.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
Jeff.....All I needed was picture number one in your series.
It says it all...stairs running perpendicular to trusses....not parallel. You already know someone got out the sawzall and started some "backyard truss wreckin"! I saw someone do this to trusses above one of the childrens bedrooms, where they wanted to create an attic loft for the kiddos. I knew as soon as I walked in the room and saw the large 8 X 10 loft complete with ladder that there were going to be some really bad truss alterations. |
My goodness.
I had a fellow electrician drill a hole through a truss. I found it, and yanked the wire and fixed the hole. I had to come up with a solid 2x4 and have it extend 2' pass the hole, and fasten it securely to the truss. IMHO, the truss only had a 1/2" drilled hole, not notched, or broken, and I had to go through fixing it with a lot of material. How did anyone think this was ok, without seeing a SE? My fix, was based on professional advisement. tom |
The kicker is, the current owners had purchased the home 5 years earlier with the ladder already installed. Their inspector made no mention of the altered trusses. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff, how many total were cut? we can see 4 in the pics. (not that 4 isn't too many!)
Sawzalls should be licensed.
Thats huge Jeff...Theres only one way a previous inspector missed that, he didnt go up there..
Timothy Hejnicki All-Specs Property Inspections (707) 428-3544 |
I found this today about 1.5 hrs ago. The TJI's rest on a ledger board bolt to the beam. I am pretty sure its wrong, but can not find it in truss joist manual. The joists are not labeled as to the manufacturer. Any thoughts?
Plus, the joists are 12"o.c. and span to about 19' 6" which the online pdf of Truss joist says it can only be 18' 3". Does anyone have other manufacturer's manuals as a pdf? Thanks Last edited by pbennett1; 3/13/07 at 2:08 PM.. Reason: photo |
| Best Truss Repair Ever!!! | srowe | Exterior Inspections | 2 | 10/24/06 9:05 PM |
| 3-2 mono roof truss anchor | dthomas2 | Structural Inspections | 8 | 10/2/06 11:36 PM |
| Nah...Who needs that TRUSS anyway ! | pabernathy | Structural Inspections | 9 | 7/10/06 8:20 PM |
| New Truss Setting System | jbowman | Structural Inspections | 1 | 6/14/06 11:10 PM |
