Go Back   InterNACHI Message Board > Specific Inspection Topics > Structural
Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera.
Old 5/5/06, 7:45 PM
William J. Decker's Avatar
Default Injection question
I have seen many foundation wall injection fixes that start leaking within 2-3 years after the fix. Common factors:
  • Owners say the urethane was injected by hand pump, rather than machine.
  • One such fix, the 'contractor' just drilled holes into the crack, stuck in a 7-11 straw (sealed with fast drying epoxy) and used a can of Great Stuff.
  • Many developers in new construction are using the cheapest people to do the fix.
  • a lot of the yellow-brown urethane foam is seen coming out of the crack.
Any comments? Have you seen this?
Thanks.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 5/6/06, 12:14 AM
Bruce A. King's Avatar
Default Re: Injection question
no, but the expanding foam can put excess pressure on materials and cause more problems.
Old 5/6/06, 2:14 AM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks.
-this is from a company who has done Injections
http://www.suredrybasements.com/sureDryCrackRepair.html
paragraphs 3 & 4
"Injecting sealant materials into wall cracks was a big breakthrough at the time.Yet, we have had to watch as continued structural movement & further concrete shrinkage have re-opened cracks to leak.Injection alone cannot provide a lasting solution as cracks get larger and soil expansion & contraction cause the foundation to shift & settle".
Injections from inside do not help lessen/relieve lateral `n hydrostatic soil pressure and tree roots which are against the outside of basement walls which cause many walls to crack,leak,bow etc. This is often why injections do not last.
The Crack Team announces its affiliate membership with ASHI
http://www.thecrackteam.com/about/pr...es/060411.html
Old 5/6/06, 7:55 AM
I do not like this you can not stop a leak from the inside permanently .
You must get at it from from the outside . A better drainage from the outside is necessary.
They must know water is the strongest solvent there is and when it starts to leak again they are just
leading the water away and it will continue to erode the wall.
I have seen various types of inside draining systems and I am not impressed .
Roy sr
Old 5/6/06, 1:37 PM
Unmoderated Guest
OOPS
Wall collapses during basement repair job
http://wwmt.com/engine.pl?station=ww...out_local.html
Old 5/6/06, 4:28 PM
David P. Valley's Avatar
A silicone injection company in my area offers a transferable ten year warranty against any leaks or they will return to repair the leak at no charge.
Old 5/24/06, 11:36 PM
cceccarelli cceccarelli is offline
Please Note: cceccarelli is a non-member guest and is in no way affiliated with InterNACHI or its members.
I own a waterproofing company in Ann Arbor Michigan. We have injected thousands of leaking cracks with sucess. We use high pressure injected poly-urethane. The PU is injected at up to 3000 psi from the inside. This forces the grouting material through the crack and into the soil where it gels in the dirt, helping stabilize the void left in the soil from erosion.
We use this method on non-moving cracks or typical dry shrinkage cracks. Epoxy injection is different.
Epoxy bonds the two halfs of the wall back togeather for a structural repair. It is only medium effictive in stopping water. We use epoxy only when a crack needs structural repair (we also have other methods such as carbon kevlar stiching).
The most common repair is low pressure injection. This only works in a very wide crack. If you see a plastic injection port, low pressure injection was used. Our ports are steel or brass. Each injection port has to be drilled into the crack or intersecting it. On the outside of the crack paste is sometimes applied to help develop greater pressure, forcing the PU deeper into the crack and keep the PU from escaping.
You can see photos of a crack repair at our web site www.basementfix.com
Old 5/24/06, 11:53 PM
Joseph Hagarty's Avatar
Joseph Hagarty Joseph Hagarty is offline
http://crackteam1.servicemagicpro.com/
Vendors that are Not Home Inspectors and have never performed a Home Inspection can advertise an ASHI Affiliation but ASHI Candidates Paying Dues to the ASHI Organization Can Not even suggest/advertise an affiliation?
Hmmmmmm.......
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Sump Pit/Pump Question Joey D'Adamo Plumbing 4 11/26/08 1:04 PM
Interesting Question? jmckenna1 Misc. Discussion 9 11/25/07 1:13 PM
WA State Legislative update hmiller Legislation, Licensing & Legal Issues 153 5/4/07 11:55 PM
Answer to a common question about GFCI's jtedesco1 Electrical 4 1/12/06 9:29 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
