Hollow block walls, 2 areas leaked (corner and basement window) due to, because of, exxxxterior cracks, cracked parging and some other exterior openings. Has NOTHING to do with a supposed bad/improper grade.
Those who tell homeowners they can fix most leaky basements by grading are full of sht! ](,)](,)
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing87#6059712678980723778
Inside shot of leaky corner…no visible crack is seen when eyeballing a lot of these corners but THAT does not ever mean, there aren’t existing cracks on the outside of the wall :-k:-k You could be SUED by telling your clients this kind of crap.
Photo album… click each photo to ENLARGE if ya like :mrgreen:
First handful of photos of… inside basement, block walls, 2 different leaky areas, some efflorescence and mold on some inside blocks… has NOTHING to do with a supposed bad/improper grade…hello!
Then see other photos… exterior cracks, cracked parging and some other openings/gaps
SELLER previously did a half az’d job in the one area/basement window hence, it did not last!
Umm, did ya see the inside photos? Yeah, just one of several reasons the inside basement system chumps want to cover/hide part or most of the interior basement wall #-o](,)#-o](,)#-o](*,)#-o
Unlike the corner, sometimes… some cracks ARE visible on the inside… like this one
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing87#6059712882841611250
If you are a home inspector and actually tell homeowners, buyers, sellers they can fix their leaky basement by regrading and other incompetent bulshhttt, you have opened yourself up to possibly getting sued or, losing your inspection fee.
And to some homeowners, sheesh, sometimes your drywall or paneling NEEDS to be removed, hello.
In order to help you find and then FIX your actual problem(s)… (honestly help you, not scrww you like inside system co’s) then, geeeeeez, your going to have to remove some of this! You may have mold etc on the basement wall and–or, on back side of the stoooooooooooopid drywall/paneling.
