Old 9/11/06, 9:15 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Insufficient end bearing?
These cracks were present on 4 or 5 joist ends in the same area that barely had 2 inches of endbearing on the beam. The overlap of some of the other joists were barely 3 inches. This was not under a load bearing wall. Are the cracks coincedence (possibly there from the manufacturer or palletized shipping or ???) or caused from too much weight bearing on the insufficient supported area?
Old 9/11/06, 9:45 PM
Default Re: Insufficient end bearing?
Looks like a split from toe-nailing...not to worry, from my perspective, if it's not too blown out.
Larry Kage, CMI
231 929 3525
Old 9/12/06, 11:12 AM
William J. Decker's Avatar
If those joists are being supported by the beam underneath, there is not enough overhang.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 9/12/06, 1:43 PM
jclark1's Avatar
That is what I was thinking, Will. However the way I read the code is the joist only needs 1 1/2" of bearing, with blocking in between. What am I missing?
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
what a non weight bearing wall (posted by clarence kluesner) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 10/25/07 8:55 PM
Bearing wall support modifications bwooddell Structural Inspections 1 5/18/07 11:44 AM
Proper End Bearing..? crichiii Structural Inspections 14 8/28/06 8:47 PM
Post Bearing Requirement hspinnler Structural Inspections 8 1/25/06 2:10 AM
