Old 11/16/12, 11:13 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Interesting
So I think the vents were added after wards. They had a whole crawlspace full of blocks to knock out but they chose these. Anyone have a good narrative for this?
interesting-williams-059.jpg   interesting-williams-070.jpg   interesting-williams-078.jpg
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
571-208-3286
http://ahouseonarock.com
Richmond, VA Home Inspector
Richmond, VA Radon Tests
Recommend US! http://www.facebook.com/RichmondHomeInspector
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/17/12, 7:50 AM
Roy D. Cooke, Sr's Avatar
Default Re: Interesting
Incorrect added Crawl space vents need immediate repair by a qualified contractor .
They have comprised the building support twice and the hold down rod is doing nothing
Roycooke@hotmail.com I prefer E-mail
"All that is necessary for the triumph of evil is that good men do nothing"-----
- -Edmund Burk
Old 11/17/12, 8:39 AM
Gerald L. Coy Gerald L. Coy is offline
Some of the foundations concrete masonry units (CMU's) have been removed to add ventilation to the crawlspace. The removal of the CMU's has compromised the support that held the homes sill plate and some joists. This has caused sagging of the floors and or low spots. Also, a hold down bolt that helps tie the building to the foundation has been disconnected from the foundation. Solutions to these issues should be discussed with a qualified contractor.
Old 11/18/12, 5:19 PM
Thanks Gerald and Roy. I pretty much copied your narrative Gerald with a changes recommend by Roy in a private message. Your help was much appreciated.
Juan Jimenez
God. Family. Home.
571-208-3286
Old 11/18/12, 6:41 PM
Originally Posted by belliott View Post
Vents added causing structural weakness.
Is that all you would have put in the report?
Juan Jimenez
God. Family. Home.
571-208-3286
Old 11/18/12, 7:03 PM
Bob Elliott's Avatar
No which is why my reports take a long time .
If I was there which I was not would include the pictures showing areas affected /implications and explained either method of correction or added framing carpenter is recommended to repair.
I did not see exactly what you saw in regard to implications.
Here is one from a couple days ago and the implications are obvious....Fact/opinion/guidence
[ATTACH]interesting-joist-rim-joist.jpg[/ATTACH]
Interesting cforman Miscellaneous Discussion for Inspectors 13 2/8/10 9:59 PM
Interesting Development at Inspectionnews jbushart Legislation, Licensing & Legal Issues for Inspectors 7 4/18/07 12:48 AM
