Came across this framing addition in the attic of a 80+ year old home. I'm not sure what to make of it. I didn't really see too much wrong with it - other than those joist hangers hanging on by a couple of nails. It appeared the structure may have been added to help support the roof, but there were no obvious settlement issues with the roof. The framing also provided a floor system in the center of the attic. I'm trying to determine if the reason for the work was to support the roof or to have some floor structure for storage. Thoughts?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
John
My guess is it was installed to help support the roof system. |
Structure looks good. Maybe problems in the past. How's the insulation and venting?
Michael J. Parker The Neighborhood Home Inspector, LLC Home inspections in Clinton, Essex and Franklin Counties in NY State http://www.PlattsburghHomeInspector.com www.TheNeighborhoodHomeInspector.com |
Looks like a great job.
Venting was good. Large gable vents at the front and rear. What insulation!? As you can see there was absolutely no insulation in the ceiling.
Whenever I see this in old homes, my first question is: What type and how many layers of roof covering are there? The age of the work doesn't appear to be that old, so the issue is probably fairly recent. The original roof sheathing was probably 1x6 or 8 boards. It is very common to see roofers install OSB or Plywood on top of these, adding a lot of weight to the structure. Were you able to see if this was the case, and how many layers of roofing material? As others have already stated, structure looks fine, for what we can see of it.
It's engineered...... I've had to fix older roof systems like that.
The LVL's are used to spread the point load across interior walls....you should look for new piers in the crawl where the ends of the lvls rest. Jeff |
Obvious that it was meant to support the roof, correct roof sag, and /or help with the rafter spread. The small bolted gusset is definitely not engineered. The h2.5 hangers added for uplift is not doing anything because the struts are only toe nailed on top of the beam created.
Whether that beam support is LVL is questionable from the pictures. Looks like an upgrade to fix a roof problem and as Jeff mentioned, there might be more than one roof covering on the roof. Hopefully this load is being transferred to bearing walls below. Having plastered ceilings, means the walls have it too, and the addittional load may cause cracks in the walls below. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Attic framing question | tirwin | Structural Inspections | 4 | 6/19/10 2:57 PM |
| Attic framing...beam question | jfunderburk | Structural Inspections | 10 | 6/3/10 6:23 PM |
| Roof decking condensation. | Homewood | Interior Inspections | 15 | 3/5/10 11:00 AM |
| Unfamiliar newer floor structure -- span too long for engineered joists? | fbartlo | Structural Inspections | 8 | 2/10/08 11:11 AM |
