rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've never seen anything like this before!!
Of course I will be recommending remediation. |
| Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America) |
It would make a great archway though lol What in earth caused that?
Its actually called a jack rafter.....at any rate......it was probably already split when they installed it.......the framer was just trying to save lumber I suspect.
It's also improperly framed.......there should be a valley plate under the jacks............you simply don't sit rafters on 1/2 plywood........its not structural. |
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's a rafter I believe. Not a truss chord.
Looks like ordinary #2 but clearly defective. The curve is likely a grain defect that was sufficient to twist the board as it dried. Can't really be sure but looks like it could have been green rough sawn lumber instead of KD. That sort of material will warp quite aggressively given the chance. Pretty bad framing as well. No plate |
Reminds me when my framer needed a long 2x12 towards the end of the new house project, the truck was coming down the driveway with this arch looking thing on the back. I looked at the framer and said WTF did you just order? He walked off and said "not that". I told the driver not to bother unloading the arch.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
The majority of the roof framing was trusses. I guess the transition was framed with 'rafters' instead of trusses.
I see all kinds of non standard construction in this area. The main thing I look for is any type of failures. Thanks for the input. |
Nice curves.....It simply needs a sister.
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
| OAHI Out Of Control - Bylaws Breached - Documented Proof | rwand1 | Canadian Inspectors | 423 | 2/25/08 6:20 PM |
| Interesting unusual truss design | badair | Structural Inspections | 3 | 2/19/08 3:34 AM |
