Did a new home yesterday. A pier and curtain wall foundation, and the sill plate was not continuous...it only existed above the pilasters for the entire permiter of the structure. (The band sill was unsupported between the pilasters.) The building inspector has passed it. What are your thoughts? Is it allowed?
Another question: how many straps do you need to see unsecured before you call it out? (I think I know the answer to this question.)
“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 12/20/06 at 12:45 PM.. |
IMHO, the house looks like it's floating a little over the foundation. Has the home owner looked at this? Might want to defer to a SE. Then have them see a lawyer.
tom |
Is this home attached to the foundation in ANY manner besides gravity? If not, they better at least put a heavy chair in each corner!
That "strapping" doesn't look much better than plumbers tape. Definitely agree about SE and...the attorney.
That could be a disaster just waiting to happen!
Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
S/B beams pier-to-pier with adequate tie-downs. Specifics really depend on local conditions.
JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Is this a home built by a builder or the Owner doing his own work .
Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
tmantsch is a non-member guest and is in no way affiliated with InterNACHI or its members.
Whiskey!
Tango! Foxtrot! Are you sure that is not just a curtain wall to seperate HIS/HER crawlspace areas? I read the thread title: "Intermittent Sill Plate" and knew this would be interesting... (New Canned comment created) "Intermittent Sill Plates are 6 feet on center and considered substandard by most AHJ in North America. Recommend SE evaluate further." |
1) Exterior sealant missing 2) Door thresholds not caulked 3) Deck was nailed to ledger board (not bolted) 4) Loose handrail 5) Loose outlets 6) Nails (the sharp end) stick through vinyl siding 7) Service entrance panel loose on the wall 8 Gutters missing end caps and downspout elbows. 9) Roof sheathing cracked (visible from attic) 10) No access panel for spa tub 11) Spa tub not on GFCI 12) Modified trusses 13) Rafters pulled loose from ridge board 14) Supply and drain line leaks under kitchen and hall bathroom sinks 15) Drain line leak in crawl space 16) No pipe for water heater TPR (water heater located inside house) 17) When you take the SE cover off, you can't get it back on because the cables and wires packed in there pop out. 18 White wires used as ungrounded conductors and not marked with black tape 19) GFCI outlet in kitchen provided for refrigerator 20) AC system over fused 21) Insulation missing in crawl space 22) Window tilt mechanism didn't function 23) Noisy ceiling fans 24) Damaged outlets 25) Open seems at tub that need grout 26) Kitchen cabinet doors mangled during installation 27) Kitchen range hood designed to vent to interior does not vent anywhere 28 Laundry vent cap outside fell off when I touched it (it was caulked to the wall). 29) Main drain going to septic tank, outside the house, was above ground, then took a nose dive to the tank. The worst new home I've ever seen! My antenna were up everywhere I looked. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 12/21/06 at 10:20 AM.. |
Joe,
The pier and curtain wall foundation intrigued me as they are not common in our area. I had to google it to learn more. From your pictures it all looks wrong to me as well. Here is something I found in my search. http://www.orangeburgcounty.org/Perm...icPierReqs.htm (5) When a pier/pilaster curtain wall system is used, the perimeter band sill must be doubled to consist of a minimum of 2-2” width members with a ledger strip. |
Harold, the band sill was doubled. The sill plate, however, was odd. The pilasters do all the support for the structure---the curtain wall just keeps the possoms out (that's what I was taught). So, structurally, it might be OK. But, still crappy.
| Bedroom window sill heights | jlybolt | Interior Inspections | 12 | 7/5/07 2:46 PM |
| sill holes | tvanvranken | Interior Inspections | 19 | 5/7/07 10:50 AM |
| Continuous ADA sill with quality sidelites | Vanessa Pesec | Exterior Inspections | 0 | 4/9/07 2:36 PM |
| Cover plate | dmacy | Electrical Inspections | 1 | 12/5/06 6:43 PM |
