Old 3/22/07, 9:49 PM
rwilcox rwilcox is offline
Default Invisi-Truss?
Another fine truss field modification or is this a new invisible truss that goes right thru cinderblock walls!
Old 3/22/07, 10:02 PM
Default Re: Invisi-Truss?
Some floor trusses are engineered to bear on the top cord area with the bottom cord notchable to a certain point.
Larry Kage, CMI
231 929 3525
Old 3/22/07, 10:09 PM
phinsperger's Avatar
I don't see the problem.
Old 3/22/07, 11:15 PM
rwand1 rwand1 is offline
The bottom cord is not bearing. The truss will be suseptible to flex. Even if the bottom cord enters the concrete block its still wrong.
Old 3/22/07, 11:30 PM
Michael Larson's Avatar
Take a look.
http://www.mii.com/artefact/download.asp?aid=26376
Old 3/22/07, 11:35 PM
http://www.sbcindustry.com/bcsi.php
http://www.sbcindustry.com/images/pu...295m2tdlmqdq87
Old 3/23/07, 7:43 AM
How does this differ from steel trusses that do not require the bottom cord to be on a bearing?
Old 3/23/07, 7:59 AM
From the links above it depends on the manufacturer.
But the jpeg Randy posted shows this to be a top bearing cord. There is a vertical section missing at the wall running from the bottom cord to the top cord.
Old 3/23/07, 8:22 AM
I guess your right Raymond, it will depend on the maufacturer. With the one you showed in your links has the vertical piece one at the very end were as Randy's pic shows a vertical member 1/2 web (approx 1 foot) from the end that your manufacturer does not. Also Randy's does not have the other diagonal peice that your does. I don't think from an engieering standpoint the two can be compared.Randy, was there any stamps that you could see.
Old 3/23/07, 9:49 AM
gbeaumont's Avatar
Hi to all,
here's a couple of top chord bearing details if it helps anyone
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/23/07, 9:57 AM
Dale Duffy's Avatar
Originally Posted by gbeaumont
Hi to all,
Regards
Gerry
Exactly Gerry.....I see them all the time in Commercial buildings, top bearing.
Old 3/23/07, 1:49 PM
We are not talking commercial, we are talking residential.
Old 3/23/07, 2:02 PM
gbeaumont's Avatar
Raymond, I have commonly seen these used as floor & roof trusses on residential structures, I also agree with Dale they are very common in commercial structures.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 3/23/07, 2:54 PM
Raymond,
I have looked at your pics and have my concerns as well. I would call for a structual inspection (either S/E or Manuf. Rep.) to visually inspect and sign off, as installed.
Gerry is correct, but look at his diagrams and compare to your pics for beefed-up top cord support.
You'll see this design in Comm. Applications, but in my area, those trusses are usually steel, not always, just usually.
You pics are not at the best angle to get a true view of the ends of the trusses, but could you tell if the were cut or finished that way. Have you noted the Manuf's stamp (ie: origin, dates, lot #, etc) to check further.
Good Question, some interesting answers.
Old 3/23/07, 3:02 PM
Regards
Gerry
Same here.
Larry Kage, CMI
231 929 3525
Best Truss Repair Ever!!! srowe Exterior Inspections 2 10/24/06 10:05 PM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/3/06 12:36 AM
Nah...Who needs that TRUSS anyway ! pabernathy Structural Inspections 9 7/10/06 9:20 PM
New Truss Setting System jbowman Structural Inspections 1 6/15/06 12:10 AM
