Go Back   InterNACHI Message Board > Specific Inspection Topics > Structural
Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera.
Old 10/28/08, 3:50 PM
Mark Nicholet's Avatar
Mark Nicholet Mark Nicholet is offline
Default Jack rafter connection
What do you think about this hanger attaching the jack rafter to the valley rafter.
ID:	24896   jack-rafter-connection-dsc06265-medium-.jpg.JPG
Mark Nicholet
Apple Home Inspections LTD
My Blog
InterNACHI member
Infrared-Certified
CAHPI(BC) member
BC Licence # 47592
Old 10/28/08, 4:32 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default Re: Jack rafter connection
Looks to me that it was made to fit the adjacent rafter (its got to be wrong).
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 10/28/08, 5:22 PM
Darren Spencer Darren Spencer is offline
They forgot the golden rule...measure twice cut once
Old 10/29/08, 10:28 PM
Bruce D. Pinel Bruce D. Pinel is offline
or use the correct hanger configuration
S & B Services LLC
www.rihomeinspectionsbs.com
FHA/HUD Compliance Inspector S127
Old 10/29/08, 11:17 PM
Simpson makes hangers specifically for that condition. That's the wrong hanger, pure and simple. An honest, knowledgeable contractor will concur, or you can recommend a structural engineer (who will also concur), but that's an incorrect connection and may be structurally inadequate.
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 11/1/08, 3:34 AM
Paul Dickerson Paul Dickerson is offline
Kenton,
Why do you think it is the wrong hanger for the application? This is a Simpson LSSU sloped and skewed hanger made for use with I-joists/rafters. It looks like the right hanger to me, and the only issue I see with the installation is that several of the nail holes in the hanger are not filled with nails. If you are not used to looking at LSSU hangers installed, they may look a bit weird, but that's how they are supposed to look. Check out Simpson's site. http://www.strongtie.com/products/co...u-lssu_scl.asp
Old 11/1/08, 3:52 AM
Originally Posted by pdickerson View Post
...Kenton,
Why do you think it is the wrong hanger for the application? ...
I know it's the wrong hanger because I was a carpenter for about 30 years, and for most of those years, we used Simpson hardware. I know this stuff by heart.
EXPERT WITNESS
(303) 717-8940
(303) 258-8289
Old 11/1/08, 11:05 AM
Michael R. Boyett's Avatar
From a quick look at the Simpson installation guides it would appear that this may very well be a compliant installation except for the unfilled nail holes. It would also appear that there are more appropriate Simpson hangers that could have been used though. Kinda looks like you are both correct.
Excellence in Inspections
Mike Boyett, TREC #7290
Capital City Inspections
Austin, Texas
Old 11/1/08, 11:13 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Plus it looks like a floor joist.
(yep take a close look) That is an i joist
Old 11/1/08, 11:53 AM
What is a wood i-joist?
Shaped like the letter "I", i-joists are composed of two horizontal components called flanges and a vertical component called a web. Wood i-joists are used as a framing material primarily in floors, but may also be used as roof rafters where long length and high load capacity are required. They are used as an alternative to sawn lumber.
Austin, Texas
Old 11/1/08, 8:29 PM
I would be curious to know why the Jack Rafters are TJI's on one side and common lumber framing on the other?
Designer can produce approvable construction documents that can be used in the field to comply with the code resulting in:
A. Construction documents that can be followed in field to achieve code compliance and reduce costly mistakes
B. Regional consistency and uniform enforcement
  1. Inspectors will receive approved construction plans that can be understood by the inspector and contractor during inspections resulting in:
    A. Structurally sound code compliant houses
    B. Reduced homeowner complaints
    C. Fewer rejections, reduced confusion, efficient inspections
Marcel
Cyr Home and Commercial Property Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards
Commercial Builder
CertainTeed
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
"UFER" Ground? see last paragraph. jtedesco1 Electrical 6 9/15/08 8:57 AM
What's this video worth? jtedesco1 Education 5 4/18/08 10:24 AM
Grounding rod connection from meter box fbartlo Electrical 37 7/28/07 1:30 PM
Rafter to Ridge connection rskinner Structural 17 8/26/06 9:33 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
