Old 4/23/08, 4:19 PM
Barry Lewis Barry Lewis is offline
Please Note: Barry Lewis is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default I Joist backer blockers
On a recent inspection I observed and noted the lack of backer blocks on these I-Joists. The builder told the client that because the I-Joists were non bearing walls they required NO backer blocks. Though we are no code enforcement officials, I still think that the backer blocks should be installed. Thoughts anyone?
Old 4/23/08, 5:20 PM
tdietrich1's Avatar
Default Re: I Joist backer blockers
Got photos?
tom
Old 4/23/08, 6:08 PM
Barry Adair's Avatar
APA: Backer blocks are used to fill the rectangular space between the outside edge of the I-joist flange and the web of the I-joist. In this respect, a backer block is quite similar to a filler block; however, it is only half as thick. Unlike a filler block, the backer block does not run the full length of the I-joist. It is only as long as it needs to be. The purpose of the backer blocks is to provide a flat, flush surface by which surface- or top-mounted hangers or other structural elements can be attached to I-joists.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/23/08, 7:20 PM
Perhaps you're thinking of squash blocks?
Larry Kage, CMI
231 929 3525
Old 2/9/09, 9:06 PM
Mike Truss Guy's Avatar
Mike Truss Guy Mike Truss Guy is offline
Please Note: Mike Truss Guy is a non-member guest and is in no way affiliated with InterNACHI or its members.
I-Joists are proprietary products. Their detailing is up to the manufacturer.
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Joist Hangers at Cantilevered Rim pdickerson Exterior Inspections 21 8/18/07 6:19 PM
Frost, Ice, & Condensation @ RIM JOIST Sean M. Jeric Inspecting HVAC Systems 4 2/5/07 6:56 PM
Plain drywall used as tile backer at shower enclosures jonofrey Plumbing Inspections 4 3/19/06 9:08 PM
