Am I missing something here?
Shouldn't these joists be blocked at the ends if they are not attached to the adjacent joist to prevent them from rotating laterally? ![]()
Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
Up here in Canada - this can be resolved by cross-bridging at third points or near mid-span? Solid blocking could also be used. Unless you see this as a code issue in your area.
Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
Bridging and blockings are usually installed in center spans when the underside is not getting a drywall ceiling.
These joists should be attached to each other with hardware and toe-nailed to the beam below it. With the spacing in your pic, the joists don't appear to be attached to each other. "Click to Enlarge" Attachment 9311 Last edited by dvalley; 10/7/07 at 5:42 PM.. |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey David, what do you think about this framing alteration? New, never lived in 4500'sf, wood frame/stucco structure. Found this added/altered roof framing configuration in one of the two attics. Appears the material was scabbed in after original construction. Don't know why painted material was used. I first thought maybe prior fire damage during original rough framing.
Thoughts? Last edited by whandley; 7/21/07 at 2:52 AM.. |
Must have dismanteled old swing sets or barricads to get the lumbe and never pounded a nail in his life. That is unbelievable. Hate to see what everything else looks like. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I know this isn't a code forum, and we all aren't code enforcement officers, but understanding where the building codes stand, helps me.
2006 IRC R502.7.1 "Bridging" Summery, not a concern unless the joist exceed a nominal 2x12. Are these bigger than 2 by 12's? tom |
I can't believe they went and stole that highway fencing and tried to use it to support a roofing load. |
I posted the wrong pic. This pic illustrates the support on a steel beam.
"Click to Enlarge" Attachment 9321 Last edited by dvalley; 10/7/07 at 5:42 PM.. |
Anti-rotational devices can be installed in midspan, using either blocks or bridging (X-bracing), but they don't use midspans in many places any more. That's because they almost all SQUEAK and they aren't necessary.
Thanks guys.
I recommended they be blocked and after some time looking at framing guides and the like, I am confident that blocking is needed. I appreciate the input. Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
However, it is considered good practice by many to install bridging/blocking between supports even for smaller joists about every 8' to 10' to help stiffen up a floor, even though it may not be required by codes. All joists (not just ones larger than 2x12) need restraint at the ends ... which is usually done with a connection to the header/rim joist at the outside walls and solid blocking between the joists over interior walls/beams (per IRC R502.7) JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wow! That's one of the most blatant things I've ever seen. Very cocky and they must consider that nobody is going to tag them for it. |
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dang, boys and girls, thet thar is one of thuh sorriest cuttin' n' nalen jobs ah ever seen. My Daddy and Granddaddy, master carpenters both, would roll over in their graves if they saw something like that. They wouldn't have let me get away with something like that on a chicken roost!
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
Rob O'Conner said:
The fact they are lapped and nailed to each other is enough to satisfy the lateral restraint at the ends requirement. Hence, the joists in the original photo require no solid blocking between them unless the house is in an active earthquake zone or other local codes require it. It is certainly a good idea to block joists over center bearing girders, and I am not arguing against the practice, but no requirement exists to block between floor joists when they terminate over a grider under the IRC except in high probablity earthquake zones... as the ICC explains it. Last edited by homebild; 2/24/07 at 12:03 PM.. |
| Deck joist blocking/bridging | jbancroft | Structural Inspections | 7 | 10/4/07 10:16 AM |
| Frost, Ice, & Condensation @ RIM JOIST | Sean M. Jeric | Inspecting HVAC Systems | 4 | 2/5/07 7:56 PM |
| Proper notching of floor joist | djohnson6 | Structural Inspections | 4 | 1/21/07 11:15 AM |
