Old 3/2/10, 3:13 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Joists and Beams
IRC does not provide guidance distinguishing whether a member is a joist or a beam.
How do you determine which term to use - joist or beam?
Joists are generally considered to be members that are a nominal 2 inches maximum in thickness and placed not more than 24 inches on center.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/2/10, 5:25 PM
Bruce A. King's Avatar
Default Re: Joists and Beams
There are many terms that differ from area to area but to keep it simple a joist is a type of beam but a beam is not a joist. A beam is a generic term that covers many structural elements. If you double up some joists you can call that a beam. Beams generally hold up several joists or other beams or point loads.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/2/10, 5:31 PM
Joe Funderburk, CMI's Avatar
I know it when I see it!
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/2/10, 5:43 PM
A joist, in architecture and engineering, is one of the horizontal supporting members that run from wall to wall, wall to beam or beam to beam, to support a ceiling, roof (or floor).
It may be made of wood, steel or concrete. Typically a beam is bigger than a joist and thus is distinguished from a joist.
Joists will often be supported by beams. Joists support the sub-floor (floor deck) directly.
The wider the span between the supporting structures the deeper the joist will need to be if it is not to deflect under load.
Lateral support also increases its strength .
There are approved formulas for calculating the depth required, however, a rule of thumb for calculating the depth of a floor joist for a residential property is; half the span in feet plus two inches.
For example the joist depth required for a 14 foot span is 9 inches.
Engineered wood products like an I-Joist gain strength from depth of the floor or the height of each joist.
A common saying in this industry is deeper is cheaper referring to the lower quality cost effective joist 14 inches and above.
Also; A horizontal member in the framing of a floor, roof, or ceiling plane.
Beam;
Horizontal or inclined structural member spanning a distance between one or more supports, and carrying vertical loads across (transverse to) its longitudinal axis, as a girder, joist, purlin, or rafter.
Three basic types of beams are: (1) Simple span, supported at both ends, (2) Continuous, supported at more than two points, and (3) Cantilever, supported at one end with the other end overhanging and free.
Also, A horizontal, weight-supporting member of a structural frame.
Old 3/2/10, 6:09 PM
Christopher Currins's Avatar
What Marcel said..
I'll add; a beam may also be a joist, but a joist can not be a beam.
Christopher Currins
Certified, Licensed
Old 3/2/10, 7:55 PM
Brian E. Kelly's Avatar
Joist a minute there Ben while I add ice to my Beam & Coke......
Old 3/2/10, 8:02 PM
Brian, two fingers of Beam and one Coke.
And don't forget to measure using the index finger and the little finger for the Beam.
Old 3/2/10, 8:25 PM
Peter C. Russell's Avatar
Sometimes a beam is referred to as a girder.
Old 3/2/10, 8:33 PM
That's right Peter,
Girder Truss used in Hip Roof framing, Girder Truss used to support steel Bar Joist. Etc.
Good point.
Old 3/9/10, 8:57 PM
jford1 jford1 is offline
Girder=usually refered to as a beam that supports floor joists or rafter joists.
Joist=framing members such as cieling, roof, and floor joists. There are usually more than one.
Beam=A framing or structural member that is oversized. Is typically bigger than a joist. Is used in "bearing" or "carrying" a load.
Old 3/9/10, 9:25 PM
Bob Elliott's Avatar
If you remove a Beam the joists may fall,but if you remove a joist the Beam will not.
Beam is the King and Joists are the pawns.
The Beam often determines where the joists will lie.
A structure can have one Beam ,but I never see just one joist.
Old 3/9/10, 9:26 PM
Wayne B. Wilson's Avatar
Surely you joists Bob
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 3/9/10, 9:48 PM
Oh I thought he was talking Whiskey and pot.
Never mind.
Old 3/10/10, 5:01 PM
So where is the Queen Bob.?
Old 3/10/10, 5:29 PM
Jeffrey R. Pope's Avatar
Girders support beams, beams support joists and joists support decks.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Unfamiliar newer floor structure -- span too long for engineered joists? fbartlo Structural Inspections 8 2/10/08 11:11 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Cantilevered Joists Steven Brewster Structural Inspections 13 5/9/06 7:32 PM
