Old 2/10/12, 1:53 PM
Chris Mainka's Avatar
Chris Mainka Chris Mainka is offline
Default Large holes
The same 60% hole applies on the engineered I beam and the wall they should have drilled multiple holes instead of the 1 Gigantic no top plate left hole.
Thanks for any help- I am heading for the books
Chris Mainka
Owner/Inspector
www.mainkas.com
facebook.com/Houston.Home.Inspector
www.linkedin.com/in/homeinspectorhouston
Home Inspections preformed in Houston and Surroundings Areas
TREC#10327
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/10/12, 2:58 PM
Default Re: Large holes
Ok found my answer in another post - The large holes are allowed in the webbing, but what sloppy work.
Chris Mainka
Owner/Inspector
www.mainkas.com
TREC#10327
Old 2/10/12, 3:23 PM
So here is the revised question - I know that the top plate is not suppose to be drilled out more than 60% - however is there an exception when the metal plates are on either side?
Chris Mainka
Owner/Inspector
www.mainkas.com
TREC#10327
Old 2/10/12, 3:39 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Chris
Attached is a table you can use.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 2/10/12, 3:41 PM
That does not appear to be a load bearing wall, so I would not be too concerned.
Randy Mayo, P.E.
573-201-8162
Old 2/10/12, 7:34 PM
Same here.
Larry Kage, CMI
231 929 3525
Old 2/10/12, 8:05 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is online now
Metal plates are for protection from errant sheetrock screws.
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Brick house nbhi Exterior Inspections 28 2/17/08 3:22 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 9:20 AM
