Old 7/28/11, 5:11 PM
Casey Patten's Avatar
Casey Patten Casey Patten is offline
Default Leaning Cripple Wall
This one has me baffled. Cripple wall built along the front of a home basement...no real apparent reason, but framing looked to be the same as the original (prior owner was a logger, all framing was rough sawn).
Cripple wall was 1 1/2" out of plumb over 2 feet. No apparent movement of any of the block foundation anywhere. Main beam twisted toward the outside wall (likely pulled by the floor joist that are toe nailed into the cripple wall), lots of cracked sheetrock upstairs.
I'm not sure what caused this; could it have been built this way, to cover for a mistake in the block foundation? I don't believe this, but not totally sure. Needed a string line to pull some measurements.
Length of cripple wall: Approx. 35 feet long, approx. 2 foot height.
Update: I saw several large piles of glass block on the property (large double lot)...possibly a temp wall for future finishing?
Any thoughts?
leaning-cripple-wall-dscn3430.jpg   leaning-cripple-wall-dscn3463.jpg   leaning-cripple-wall-dscn3464.jpg
Root River Inspections
Serving Rochester, Winona, Red Wing, Austin, Albert Lea and all Minnesota areas.
Vice-President, Southern Minnesota Chapter of InterNACHI
Direct: (507)254.1391
Web: www.arochestermnhomeinspector.com
Email: rootriverinspections@gmail.com
"The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help'" - Ronald Reagan
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/28/11, 5:30 PM
Jeffrey R. Jonas's Avatar
Default Re: Leaning Cripple Wall
FYI... I just spoke with Casey on the phone. He will be back to post some additional information.
Old 7/28/11, 5:31 PM
Updated info on original post...
Old 7/28/11, 7:27 PM
No go on the glass blocks. Apparently they were something the previous owner salvaged from the old school in town, but his executor knew nothing about plans to use them in the wall.
Old 7/28/11, 7:41 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Did you check the opposite wall for any movement?
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 7/28/11, 8:08 PM
Yes...there was no evidence of movement on any of the other walls. No cracks (one minor crack on the front wall), no shifted block...nothing.
Old 7/28/11, 8:39 PM
Is that main beam cut from one piece of sawed lumber? If so maybe the beam twisted as it dried over time and pushed the joist.
Randy Mayo, P.E.
573-201-8162
Old 7/28/11, 8:43 PM
The main beam is a triple of rough sawn lumber. Total dimension was 5 3/4" wide, 8 3/4" height. They were nailed together, but are not shown in these pictures. Which beam are you referring to?
Old 7/28/11, 8:49 PM
The beam I am talking about is the main beam down the center, probably the one you described. I have seen 6x6 treated posts twist 45 degrees as it dried out due to some type of defect in the grain in the wood. I was checking the possibility this main beam did the same. Less likely when three are nailed together, but still possible.
Randy Mayo, P.E.
573-201-8162
Old 7/28/11, 9:17 PM
Ok, I'm with you now. That beam is tilted slightly toward the exterior wall, but shouldn't be enough to throw it 1 1/2" inches out.
Old 7/28/11, 9:53 PM
Were the floor joist nailed to the main beam and cripple wall?
Randy Mayo, P.E.
573-201-8162
Old 7/28/11, 10:07 PM
Toe nailed to the top plate of the cripple wall. They were only nailed to the sistered floor joist for the other half of the house (on top of the main beam). I did not see that they were nailed to the top beam.
You would think there would be some sign of movement from the opposing wall to make it move, but I didn't see anything. There was moisture along that opposing wall at the floor/wall connection point.
Old 7/28/11, 10:48 PM
Bruce A. King's Avatar
A client hired an engineer per my recommendation once for what looks like the exact same issue. Just a badly constructed cripple wall on a house less than 5 years old. The engineer signed off on it as a non-issue. The client was a general contractor and bought the house as far as I know.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 7/29/11, 12:25 AM
Hmmm...Bruce, this house is 25 years old. My client had this as one of his major concerns, even during the scheduling phone call. His words were "If it looks wrong to me, I'd think it's wrong".
Wound up stating that the wall was out of plumb a significant distance, needed to be looked at by an engineer and repaired as needed.
Like you said...if the engineer signs off, what else can you do?
Old 7/29/11, 9:42 PM
Casey
One last thought... is it possible the bottom of the cripple wall was pushed in?
Was the cripple wall anchored into the blocks?
Randy Mayo, P.E.
573-201-8162
Do you report the absence of house wrap? jfunderburk Exterior Inspections 17 6/17/11 10:04 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
