No problem,
We can move that column over a few feet.............. Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:33 PM.. |
Just put another nail in it.
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Since peir pads are from 3'x3' to 4'x4' it is also not likely that the post is resting on it's pad.Therefore slab failure is also likely.
That beam should have more overlap on the individual members, not very stable.
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Homeowners excuse to the ambulance driver; But i had to put the water heater close to the washer, do you know how much copper cost these days.
check out the floor joist over the post.
What are you guys worried about, they do have a continuous member going through the splice.
Joe, where do you find these places? ha. ha. Man, look at this for a second, Wire chaffing on duct shim under stair tread due to improper layout Nothing left of the bottom side of the stringer, but thank God it was inset. Who was coming down the stairs and did he have a handrail to hold on to? Polybag insulation??? TPR valve on the electric water heater, is it there? Tie wrap electrical wire to copper lines. Adjustable jacks, they approved in your area? As mentioned, perma-jack moved, where is the footing under slab now.? Just thought I would mention a few items, I know you saw all of that and then some right.?? Ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I can see the deflection in the beam in the first picture. Of course all splices should occur at a support, but I'll take five bucks for every beam in houses that are like this one.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
i see the handrail, marcel, but don't you need balusters on basement stairs if it's a living space?
Good point though, does the stair code requirements apply to unfinished spaces that are used solely by adults for routine storage or washroom facilities? Haven't found anything to this regard, maybe others can help on this one. How would you address this one? Marcel </IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The pictured handrail probably predates any code requirements for balusters or returns and is therefore code-compliant, if it was code-compliant when it was installed.
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
The design of this beam is no good. Just plain Stu____!!
Barry Lewis is a non-member guest and is in no way affiliated with InterNACHI or its members.
Standpipe on washer greater than 42"(IRC)?
Shutoff on water heater? |
| Main Beam Support | jhagarty | Structural Inspections | 15 | 5/13/07 8:42 AM |
| Main disconnect at meter instead of main panel. OK? | kshepard | Electrical Inspections | 14 | 11/8/06 7:24 PM |
| Main Electrical Shut-off? | jpassailaigue | General Inspection Discussion | 10 | 3/24/06 3:19 PM |
