Old 7/9/09, 10:13 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Main wood beam shims
If you saw this in a 3 yr. old condo, would you comment on it? If so, how & why?
Thanks in advance.
main-wood-beam-shims-1488-riverwood-dr.-unit-defiance-050.jpg   main-wood-beam-shims-1488-riverwood-dr.-unit-defiance-051.jpg   main-wood-beam-shims-1488-riverwood-dr.-unit-defiance-052.jpg
Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America)
Old 7/10/09, 7:21 AM
Default Re: Main wood beam shims
Bump.
Old 7/10/09, 8:23 AM
I certainly would, improper beam support.
Old 7/10/09, 11:02 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
I'd call it out as a concern. Approved/inspected by the AHJ, and may have been acceptable to the design professional. Doesnt mean its right, it just means it was inspected and approved.
This is why we call it out as a concern...
Old 7/10/09, 11:04 AM
David P. Valley's Avatar
That is most definitely an issue in my book.
Improperly supported carrying beam......
Old 7/10/09, 11:38 AM
Unmoderated Guest
Someone may have approved it initially, but I wonder what they would think of it now, since the lower shim appears to have crushed, allowing the right-hand beam to settle. I also wonder whether the right-hand beam had sufficient bearing area to begin with, and if not, that may also be responsible for the settlement.
I am not an inspector, as you can read above, but if I were, I would certainly suggest that it be evaluated by somebody under whose area of expertise this condition falls. It may have been "right" when it was built, but it ain't right no more.
On second thought, what may have happened is not settlement of the right-hand beam, but inadvertent jacking up by a fraction of an inch of the left-hand beam, when the lower piece of shim (perhaps tapered intentionally) was driven into place.
Old 7/10/09, 2:51 PM
Thanks for the replies, fellas. BTW- this was the same across the entire span, about 4 or 5 columns that looked about the same as this one.
Old 7/10/09, 6:44 PM
You have a couple problems here....
1. The microlams splices are not centered over the pier.
2. The PT (pressure treated) lumber is not large enough to give proper support / transfer to the pier.
3. The PT blocking is split
4. Improper fastening of the microlams is obvious.
I would like to see pictures of the pier and footing for more evaluation.
Jeff
Old 7/16/09, 12:18 PM
dhelm's Avatar
dhelm dhelm is offline
Don't know about other areas of the country, but in this seismic area columns and beams must be positively attached, and that doesn't mean toe nailing.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 7/16/09, 12:45 PM
mnahrgang's Avatar
I started out with a NO answer, but then your pic 2 & 3 raised some concern. The shims are showing signs of crushing, and in pic 3 you can see the beam on the right isn't supported very well and is settling. My comments would at least not that. I would also check out what is happening at the foundation where these beams attach. There seems to be some settling.
Mark Nahrgang
www.HeyMark.info
Old 7/20/09, 1:34 AM
tneyedli1's Avatar
tneyedli1 tneyedli1 is offline
Please Note: tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks in advance.
Quick fix for now.
He'll get back to it on Monday.
Monday of which month/year he didn't say.
One new construction flaw, so I wonder what the other 14 looked like?
T.Neyedli CHI
www.aphahomeinspections.ca
ASTTBC/BCIPI
BPCPA # 47827
Can someone explain why wood in contact with concrete causes rot? gromicko Miscellaneous Discussion for Inspectors 46 1/17/11 12:15 AM
The Rise and Fall of CCA Wood Preservatives mcyr General Inspection Discussion 3 5/4/08 12:19 PM
Slate Main Beam Shims jevans Structural Inspections 2 2/27/08 6:50 PM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 9:30 AM
