Old 2/15/06, 2:08 AM
Stephen W. Stanczyk's Avatar
Default Manufactured home crawl space
1979 manufactured home, pit dug out for crawl space. Sits on tie-downs and concrete blocks. Owners put up wood frame to support the skirting. Attached the metal skirting and then back filled against the skirting for a level grade outside the home.
The wood frame is not pressure treated and is in constant soil contact in the crawl space. I can explain the problem, but as part of a wdo report required in this state, I am at a loss for a recommendation. Short of removing the frame/skirting and complete regrading which is near impossible in this subdivision, I'm not quite sure what else to say.
Any help is appreciated.
The second picture also show the a/c condensate line emptying under the house.
Stephen Stanczyk
Old 2/19/06, 1:35 PM
Patrick Bolliger's Avatar
Talking Re: Manufactured home crawl space
This is one of those situations where you scratch your head and think "why didn't the installer think about doing this right the first time" kind of approach.
I can see some of the wood framing being cut to avoid soil contact and perhaps some CMU's installed on top of grave to fill the space thereby changing the soil / wood contact situation .
Other then ripping that whole skirt out and pouring a concrete slab with a lip for the perimeter to act as a "footing / foundation " for a wood frame I can't see what would be a cheap alternative. Do you know of any plastic products that could replace that "framing"?
That HVAC condensate line has to be extended outside of crawl space ..
Old 2/19/06, 4:23 PM
twheeler
Guest
Posts: n/a
Default Re: Manufactured home crawl space
I would make mention of the fact that the wood that is in direct contact with the soil, is subject to premature rotting. Recommend a licensed contractor assess further to determine the cost of repair.
This way, you identify a problem, and ask that a specialist be contacted to assess further, this takes you out of it and places the attention on a contractor.
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 230 3/21/12 9:35 PM
Buyers Best Home Inspections ddinwoodie Miscellaneous Discussion for Inspectors 6 9/4/06 7:20 PM
