Manufactured home roof connection at the ridge appears to be incorrect. No collar ties or other methods to connect and secure the two halves. Any opinions?
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Appears to be sloppy framing. Were there ceiling joists running the same direction as the rafters, tying the walls together? If so, there is nothing making the rafters pull away from the ridge. If there are ceiling joists that are not connected to each other to make one long continuous joist, the angle of the struts could push the rafters away from the ridge. You should be able to find evidence of that elsewhere in the house though. Ceiling drywall pulling away from walls or something similar to that.
In Canada (at least in the Ontario Building Code) collar ties are used for intermediate support for the rafters, not to keep them from pulling away from each other. Benchmark Home Inspection Services. http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas. |
Before you call it out, call the manufacturer with the serial number and ask him to tell you what the plans call for. In your report, report the defect in relationship to the manufacturer's instructions.
While you are speaking to the manufacturer, inquire if any of these defects would affect the warranty. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Was not able to locate the manufacturer's label, home built in 1986. I do agree that the framing is very poor. No evidence of drywall movement. I should clarify, it is a modular home.
Without that tag, you are missing some very important information. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
I have never inspected a modular home nor have I worked on one. I have seen them going down the road, usually half width (or less?). This makes me think that they have to connect the two halves at the ridge once it is installed. Maybe that is where the poor framing happened? I would think if that was the case, both halves would have a ridge board.
The modules are built in a factory by contractor A and assembled by contractor B, according to a set of plans. It was inspected before it left the factory and the info was placed on the tag, along with the serial number. You do not know if you have a defect in the assembly if you do not have the plans. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
When we see something like what we see in picture #1, we know we have a defect. Just don't know why without further digging.
I usually find the serial number tag in a bedroom closet.
House was very cluttered, including the closets. Did not find the tag at the panel, may have missed it under the kitchen sink, the cabinet was filled with stored items. A few more images:
When I find something like this. I am not afraid to say, I don't know. I then recommend a person in the perspective field to evaluate further and advise if any repairs are necessary. Better safe than sorry is my take.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
Another thing to keep in mind about a modular home. If there is a rectangular sticker on the outside of siding near where the taillights would be. It is a manufactured home. The sticker will even say "manufactured". Most Realtors have no idea what they are listing. Sad but true.
Buyer is walking away from this home. Many other issues in addition to the roof structure.
Just curious; do modular homes have a good or bad reputation where your are? Two manufacturers close to where I live. Both have a good reputation.
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| Inspector listings by county | rcarter | Miscellaneous Discussion for Inspectors | 8 | 8/22/09 10:40 AM |
