View Poll Results: WHAT COMBINATION OF LETTERS INDICATE MORTAR TYPES?
M A O N W 1 5.88%
M S N W R 3 17.65%
S N O R K 2 11.76%
M S N O K 11 64.71%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 11/2/07, 8:20 PM
Default Masonry mortar types
What combination of letters indicates mortar types?
Old 11/2/07, 10:45 PM
Unmoderated Guest
Default Re: Masonry mortar types
Wild guess: M S N W R
Old 11/3/07, 8:30 AM
ldapkus ldapkus is offline
O N S M K - Astm C 270
Old 11/3/07, 11:35 AM
Jeffrey R. Jonas's Avatar
http://www.cement.org/masonry/cc_mortar_types.asp
Old 11/3/07, 11:47 AM
Nice.
Some of you are on the right track.
See how we all learn?
This BB is worth millions. ha. ha.
Excellent.
I will give my version of the correct answer this afternoon.
Marcel
Old 11/3/07, 11:56 AM
Barry Adair's Avatar
What type does a "MASON WORK" with to get the stongest mix?
http://www.graymont.com/applications..._designs.shtml
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/3/07, 12:21 PM
Thanks Barry, and would you know which one to use on glass blocks and or a chimney?
Marcel
Old 11/3/07, 12:34 PM
bzimbelman bzimbelman is offline
Marcel
M for chimneys
Glass block has a different one, 1/1/4 I believe.
Then there is straight lime mortar, which some call L
Old 11/3/07, 4:12 PM
Well, since Barry gave out the answer, I will try to summarize.
M A S O N W O R K
The five typical mortar mixes designated types M,S,N,O and K are labeled so because each is an alternate letter in the term MASON WORK in descending psi strength. These designations were assigned in 1954 and replaced the mortar designations A-1, A-2, B and C.
M 2,500 psi
A
S
1,800 psi
O
N
750 psi
W
O
350 psi
R
K
75 psi
Know that a weaker psi mortar is not a "bad" or inferior mortar to one with a higher psi. A lower psi mortar has much better adhesive and sealing powers than a higher one. Mortars are selected on the balance between these attributes as to what is required for the building situation on a particular spot in the job. A type M mortar with its high strength yet poor adhesion and sealing can be a bad choice for one area of the job and just what is needed in another.
Type M mortar
This uses a 3 / 1 / 12 mix and results in a mortar with a 2,500 psi compressive strength. Type M is used for below grade load-bearing masonry work and for chimneys and brick manholes.
Type S mortar
This uses a 2 / 1 / 9 mix and results in a mortar with a 1,800 psi compressive strength. Type S is used for below grade work and in such areas as masonry foundation walls, brick manholes, retaining walls, sewers, brick walkways, brick pavement and brick patios.
Type N mortar
This uses a 1 / 1 / 6 mix and results in a mortar with a 750 psi compressive strength. Type N is the normal, general purpose mortar mix and can be used in above grade work in both exterior and interior load-bearing installations.
Type O mortar
This uses a 1 / 2 / 9 mix and results in a mortar with a 350 psi compressive strength. Type O is a lime rich mortar and is also referred to as "pointing" mortar. It is used in above grade, non-load bearing
situations in both interior and exterior environments.
Type K mortar
This uses a 1 / 3 / 10 mix and results in a mortar with but a 75 psi compressive strength. Type K is useful only in historic preservation situations where load bearing strength is not of importance and the porous qualities of this mortar allows very little movement due to temperature and moisture fluctuations. This aids in prolonging the integrity of the old or even ancient bricks in historic structures.
Straight lime mortar
This uses a 0 / 1 / 3 mix and is used now only to recreate the construction and review the methods of times past or maybe for purely visual purposes. This mortar was made before Portland cement was available in many areas and so this is what was used. Sometimes you'll see straight lime mortar called "L" mortar (for lime) but this is not designating it as "type L" mortar as in the MSNOK types. There is no "type L" mortar.
Marcel
Old 11/5/07, 8:34 AM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
very nice info Marcel! thanks
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 11/5/07, 8:41 AM
Marcel
Has a permit been pulled for the work in question?
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/11/07, 11:36 PM
arussell arussell is offline
Please Note: arussell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks Marcel
that's some great info.
alan
Frozen mortar or poor mix kshepard Exterior Inspections 2 6/14/07 12:02 PM
Brick and stone Mortar deteriorating rjack1 General Inspection Discussion 5 4/11/07 12:50 PM
Fireplace Enclosure jpope Interior Inspections 19 10/25/06 6:08 PM
Wood plates/shims on masonry piers supporting girder? rmc3inspection Structural Inspections 6 7/11/06 7:49 PM
Historic Masonry Re-pointing: Repair or Ruination? mbryan Exterior Inspections 4 2/21/06 10:49 PM
