Old 10/10/11, 2:55 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Metal roof question (s)
Did an inspection on this house today. I have not seen this style of roof/structure before and need some help. Home built around 1930. I could not get in the attic as the opening was over the stairs to the basement and could not set up my ladder. I was able to stick my camera up through the opening and snap some photos though. Also the attic hatch had holes in it?, why? The ceilings were made of thin metal panels too. There are some metal homes in this area but the rest of this home was stick built.Any information on this type of structure would be greatly appreciated.
metal-roof-question-s-001.jpg   metal-roof-question-s-034.jpg   metal-roof-question-s-048.jpg   metal-roof-question-s-139.jpg   metal-roof-question-s-140.jpg
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/10/11, 2:56 PM
Default Re: Metal roof question (s)
More photos.
metal-roof-question-s-143.jpg   metal-roof-question-s-145.jpg   metal-roof-question-s-146.jpg
David
518-505-8305
Old 10/10/11, 6:31 PM
Looks like a catalogue home.
Unfolding the mystery is a continuing process; it may be difficult to prove a structure is a Sears' mail-order house. However, the best way to determine a mail-order structure is to go to the attic and examine exposed beams for numbering or markings. Many researchers have also discovered while removing walls for an addition that the studs are numbered or stamped with the Sears & Roebuck or another mail order company's imprint. Even windows and storms are numbered correspondingly. Look carefully for any original lighting or plumbing fixtures. The Sears name may be printed on the surface since these items were typically ordered from the kit. The clues are there, you just need to carefully notice them.
http://www.wisconsinhistory.org/teac...me.asp#history
Old 10/11/11, 8:11 AM
Would this be considered a truss system? And how concerned should I be with the rusting on the underside of the roof?
David
518-505-8305
Old 10/11/11, 9:46 AM
With a little help on another site and with Barry Adair supplying a link (thanks Barry), I found this home listed as a prefab home. Only this is the company that made it wasn't in existence until 1947. The listing of this home had it being built in 1930.
http://en.wikipedia.org/wiki/Lustron_house
http://www.lustronpreservation.org/
David
518-505-8305
Old 10/11/11, 1:28 PM
The roof looks like it's in pretty good shape for a home of that age. The concern is the residual thickness of the metal roofing. Rust was visible underneath and some rust spots on the roof. Good ventilation may help reduce the ongoing rate of corrosion.
Obviously replacement of localized areas of failure with new matching shingles will not be an option, although metal can be patched/repaired unless damage is too widespread.
Describe what you see... some corrosion, mention that lack of access to the attic limits your evaluation, disclaim the roof and recommend evaluation by a qualified contractor.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/11/11, 7:47 PM
William Warner's Avatar
William Warner William Warner is offline
Won't be too many contractors in the entire country qualified for a Lustron home or building.... unless they do their research.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 10/11/11, 11:29 PM
Basically they'd just be looking to see how close the metal is to rusting through.
(303) 717-8940
Old 10/12/11, 3:34 PM
Agreed. And certainly some form of treatment should be recommended for preservation if the new owners plan to maintain the original integrity of this unique and rare home.
Old 10/12/11, 4:00 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Kynar 500 is what I recommend. Strongest and most durable metal paint. All areas of rust must be treated first.
www.kynar500.com
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/12/11, 4:18 PM
I gave the buyers some links to web sites dedicated to preserving these homes. I'm sure they will find information there on how to maintain the home.
David
518-505-8305
Old 10/12/11, 6:52 PM
I give credit to BA for introducing me to these homes earlier this year. There are several in my area on the registry. They certainly have unique features and interesting history! Not that I will rush out and buy one... but neat to know about nonetheless!
Old 10/12/11, 7:02 PM
Barry Adair's Avatar
if you or anyone reading ever hear of a Lustron for removal-sale let me know
i've just missed purchasing a few haul offs for under $7K and would consider having one for a 2nd on our lake property for the kids and grandmonsters
already have a trucker on standby whenever required
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/12/11, 7:08 PM
You got it!
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 11:47 AM
Inspecting a metal roof dmacy Exterior Inspections 13 11/3/07 12:08 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
