Old 12/12/09, 2:43 PM
cbollin's Avatar
cbollin cbollin is offline
Default Modular home
Is it normal for the Rafters in Modular Home be 2X6 then cut down to 2X4. I could not get up in to the attic to see if engineered that way. they where all this way .
C. Bollin
Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America)
Old 12/12/09, 3:52 PM
Jeffrey R. Jonas's Avatar
Default Re: Modular home
Do you have a photo of the other end of the 2 x 4's? Doesn't look right to me. If it was engineered that way, the ends would have been butted together. Also, typically it would be designed so that a full sheet of sheathing covers the joint, not end at the joint. Does the roof change pitch at that point?
Old 12/12/09, 3:56 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
These are hinged joints, and are meant to be this way, although they look a far apart. Am I correct in assuming that your pictures are not oriented correctly? Hard to tell which way is up. They ship houses with part of the roof laid flat, and then stand them up during setup. The load ratings and distances determine the need for 2x4's vs 2x6's. Typically, the manufactured industry saves a buck everywhere it can.
Old 12/12/09, 4:11 PM
http://www.youtube.com/watch?v=7xYfd...eature=related
You cant see them raise the roof, but you get the idea.
http://www.youtube.com/watch?v=8lDVkjx_nnU&NR=1
This one shows it best, about 45 seconds
Old 12/12/09, 4:16 PM
cbollin's Avatar
I could not see the other eds of the rafters due to the insulation. It did not look correct to me either I do know some rafters are engineered in this manner but I thought there was some type of marking on them to indicate this. the photos are correct I am looking up at the rafters and the sheeting is the roof. the roof does not change pitch. To make this Inspection better the building Dept lost the CO on this Home. The Building Dept told the new buyer they will use my Inspection report for the new CO. I told them a Home Inspection is not a Code check and they had no problem with that.
C. Bollin
Old 12/12/09, 4:45 PM
Alphine Hinge Plate for Modular Housing tilt-up roofs.
Old 12/12/09, 4:50 PM
You can see a picture on the design of
Hinged Truss here.
Old 12/12/09, 6:02 PM
Thanks Marcel, I was looking for that image, and couldnt fine one fast enough.
Old 12/13/09, 12:05 AM
grusk grusk is offline
Please Note: grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chris, when you inspect a hinged roof system you need to check to see if the hinged knee braces are properly nailed and strapped to the king post and that the marriage/mate line is fastened per the manufacture's specifications at the ridge and ceiling beam and/or top of the king posts.
Gary
Old 12/13/09, 10:52 AM
Doug Edwards's Avatar
This is why Marcel gets the big bucks.
- John Stuart Mill
Old 12/13/09, 11:18 AM
Don't know about the big bucks Doug, but thanks.
And here is a good link for the topic of hinged plate trussess for Modular Homes.
http://www.ufpi.com/product/dhp/index.htm
Click on the photo for animation.
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
