I inspected a condo today.
Observed moisture along the base of the wall. It was only on one wall and it isnt a outside wall. This is a wall between the condos and not a ouside wall. Looks like a potential blocked or broken foundation drain. Also the floor had excessive cracking and it looks like there may have been water intrusion at the cracks from the discoloration on the floor. My moisture meter didnt detect any current moisture but it sure looks like there was previous signs. How would you report the condition? Dave Last edited by dmacy; 10/28/08 at 7:31 PM.. |
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
White efflorescence (powder substance) on block wall indicates moisture is in contact with the masonry. This does not necessarily indicate that intrusion will occur. I recommend checking drain lines for proper operation. Also, a water proofing paint could be applied to the interior side of the block if necessary. Efflorescence is found on many homes without water intrusion occurring inside the home. But, it should alert you to the possibility that future steps may be needed.
Steve |
http://www.factsfacts.com/MyHomeRepa...lorescence.htm Dave,was the condo new? It may have been from water entering the blocks during construction. |
Larry
Actually it was older built in 1974. Thank you |
Efflorescence is indeed a sign of water penetration thru a concrete/masonry wall.
And remember there are two types of foundations ... those that are leaking, and those that will leak ... JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Do you call out efflorvesence | gbrasseur | Miscellaneous Discussion for Inspectors | 10 | 4/13/07 12:51 AM |
