Old 1/19/10, 2:08 PM
Wayne B. Wilson's Avatar
Default Moisture reading on a slab
I got this lady that called me with a a problem.
She and her husband are sick.
She has had a mold test
It should count was equal to the outside ( i didn't do the test)
Hardwood moisture 17 to 18 %
Tile 22 %
Tile have cracked and been replaced and cracked again.
Efflorescent along the outside block.
Poor drainage around the outside.
I have refered to a foundation engineer . I am thinking a core drill may be needed to see if gravel and barrier had been used.
What do you think any thoughts
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/19/10, 2:41 PM
ldapkus ldapkus is offline
Default Re: Moisture reading on a slab
Hardwood is wet for sure. I don't know how you got your tile reading.
Old 1/19/10, 3:01 PM
James E. Braun, CMI's Avatar
What is the bottom of the walls reading. I am guessing you got you tile reading by scanning. You can email the lab report at jbraun@mo.nachi.org and I will look over it for you, just to make sure. Also knowing what chronic symptoms that are experiencing would be a great help.
Old 1/19/10, 3:53 PM
Check your mail James
Thanks
Old 1/19/10, 9:56 PM
Thanks James for your time and call. It was greatly appreciated . Another fine example of Guys on here stepping up and helping other members.
Old 1/21/10, 10:49 AM
I was glad to help. If anybody needs any free advice on mold, especially interpreting lab reports and conditions when an occupant is sick, feel free to contact me at jbraun@mo.nachi.org .
Fighting Mold — The Homeowners' Guide from CMHC mkyriacou IAC2 Indoor Air Forum 1 9/17/09 2:32 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
