New construction. Moldy trusses (probably left out in the rain.) How would you address this issue? Moisture content in the wood was negligible. (I have a pretty firm plan for how I will address it...wanting to get others thoughts.)
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
It could be a problem when the occupants have health issues that are later blamed on this. Try to disprove something like that and good luck. Or if its just discovered later and they need someone to pay for the cleanup, then its a problem.
The SOP will not always prevent an issue from escalating. My policy is to report every single item that could be considered by anyone, including attorneys, contractors and engineers to be an issue in the future. This is not exceeding any bounds, its just good ole inspecting and reporting. Its not our job to decide what is important to our clients, let them decide or get further evaluations done as they deem necessary. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Don't see really what there is to "address". You see it and have pics so you either report it or you don't. Not reporting it is not an option. How it's dealt with is best left up to the legal eagles. This has the potential to get ugly. IMO, the builder should clean/replace. . |
I had a case similar to this one. Notice there is no mold on the sheathing, I bet if you dug under the insulation you would find mold growing on the ceiling joists, either way the mold happened during construction. Mold will grow on sheathing at a lower percentage of moisture than the regular framing lumber. In my case the occupants of the home got severely ill because black mold particles floated out of the ductwork and covered everything like dust. The buyers of the new home got their money back, I imagine the contractor just did piss poor clean-up and put the house back on the market. Sad but true.
I've seen 2x4's come off a lumber truck from the yard looking like that.
If that's mold- and it looks like mold- unless it's provided with enough moisture to start reproducing (approx. 20% in the host material) it will not release spores. Since the health threat to humans is from elevated spore concentrations in indoor air, I woudn't consider it a problem. If ohter trusses had the same discoloration, they may have arrived onsite from the truss company looking like that. If only the trusses in that area were discolored, it may have been from a past leak, but you should see discolored sheathing. It might have happened while they sat onsite, but they usually dry too fast around here. I don't know about there. I'd mention it's presence but wouldn't make a big deal out of it. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I have seen many clients make a big deal out of it during the pre-drywall stage and the builders are having it cleaned up for them. I do not cause this, the clients have already noticed it and just want it noted in the report.
Some builders are asking the buyers to sign a document that "prevents the buyer from making a claim later" if they clean it up for them. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
"Inhaling or touching mold or mold spores may cause allergic reactions in sensitive individuals. Mold does not have to be alive to cause an allergic reaction. Dead or alive, mold can cause allergic reactions in some people." Imagine how many spores will be released if there is ever a leak in that attic. Or what if the AC drain pan fills with water and contributes to high humidity conditions in the attic air. Finally, will a future buyer freak out when their home inspector points it out? I consider it a very negative condition! I got a ball-park estimate from a mold remediation contractor today: $2,500. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
At predrywall stage, (house not air tight) what can you do? Just tape samples?
I doubt anyone could truly clean every edge of every truss and floor joist in a house. Enough sampling will show mold for sure. Most clients are happy if they see a substantial improvement but I will send them to you if I can. If mold gets sprayed with a bleach mixture or some chemical to kill the mold, will a tape sample still show the mold spores in a lab? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
What will happen if that colony gets a lot of moisture won't be much different from what'll happen if any other part of the attic gets a lot of moisture. With enough moisture, it doesn't take very long to grow a colony that size. Natural humidity alone won't do it. If there's a leak or a malfunction that elevates moisture levels to an adequate level, any material in that attic with mold on it- and that's every surface in the attic- that's wet enough is going to start growing mold. And that's not only true for that house... it's true for every house. Will a future client freak out over it? Not if they're educated and understand the danger. Some people freak out about ants... or aliens. It's not a problem unless it gets wet... just like the rest of the house. You got that quote because that guy makes money doing mold remediation, not supplying neutral third party expert opinion on the necessity for mold remediation. I'm just saying what I think. You should do whatever you feel you have to, Joe. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
So mold remediation is gold too.
I used to get all worked up over the mold argument, but not any more. People think what they think according to their experience. I spent a lot of time researching mold trying to figure out what was real.
It really does kill people and it's not something to be taken lightly, but my take on it is the result of my research and I'm satisfied with my understanding. The reaction of different inspectors to the mold issue is a lot like the reaction of different inspectors to presidential politics. You just don't often change people's minds by arguing on the message boards. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Kenton, I posted this to get feedback. Thanks. I understand your point.
Essentially, I told them it is "mold-like" and they should seek the services of a mold specialist or mold remediation company. For CYA reasons, there is no way I'm down-playing moldy trusses in a new home---will gladly give that ball to someone else. If they want to pay me to sample it to check the spore count, I'll do that for them too. I didn't recommend it--gave them that as an option. I got the feeling the client will walk away from the home...she was pretty upset about it and I'm not going to tell her it's OK because it's dormant (now). I want to hear others give their input also. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
$2,500 to work in a 120 degree attic, decontaminating 40% of the structure of a 1,200 SF house. Sounded fairly reasonable to me considering the liability.
"Surface sampling can provide information regarding whether the visible apparent mold is in fact actual microbial growth (mold) or not, measure the relative degree of the mold contamination, and can serve to confirm that the sampled mold growth may be producing mold spores in the air." (NACHI IAC2 training program.) “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 8:43 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
