How much moisture comes from the soil in a crawlspace with an exposed dirt floor?
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Where do you live?
So the answer is related to where you live?
Let's say TEXAS. |
Vented or non-vented. Any problems with the stem wall? Downspouts?
I answered before your second post. Let's say Ohio Valley. We get rain now and then...
And even more related to the particular lot, drainage etc.
It varies from no problem all the way to major issue around here. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Depends of the type soil, amount of foundation proofing, topographical conditions, number of vents........whether etc.
Jeff |
The question is "How much moisture comes from the ground?" In gallons or pounds. I have found an answer of 100 pounds (12.2 gallons) of water can come from the exposed crawlspace ground per day per 1,000 square feet of a house. (averages) Agree? Or do you have another calculation? Last edited by bgromicko; 6/28/10 at 4:21 PM.. |
Gravel Bedrock Sand Clay You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Y'all may be missing the point, Ben.
You gave an illustration with the word "can"... but is arbitrary. It just depends on many different factors and different areas of the USandA. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Really?
Oy. I thought that water evaporates at a rate that is (on average) constant. So, Let's take where you live... Do you know how much water can evaporate from the ground - in relation to your zip code? Jae, Ohio, what's the rate? Michael, MN, what's the rate? Currins, from IL, what's your rate? Last edited by bgromicko; 6/28/10 at 5:16 PM.. |
Ben I can take you to at least 5 different soil types with 30 minutes of my location.
What are you going for. Your number is very high IMHO. Where is it from? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Doing research for the next InterNACHI course...
Several studies have considered how a crawl space can contribute to the moisture level in a building. Britton reported an average evaporation rate of 12.1 gal/1000 ft2/day (490 g/m2/day or 0.10 lb/ft2/day). But this is old data. (R.R. Britton, Crawlspaces and their effects on dwellings.) I'm looking for new research. Moist air from the crawlspace is often the most significant source of moisture entering a home. I've also read - If soil is damp in a 1,400 square foot crawl space, as much as 20 gallons of water a day can evaporate into the air. Dan Morrision from GreenBuildingAdvisor, "About a gal. per 44 sq. ft.) evaporate from bare soil in a crawl space" Last edited by bgromicko; 6/28/10 at 5:58 PM.. |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
