Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
The nails that are sticking out of the concrete stem wall (pointed side of nail sticking out) are left over from the form boards used to create the foundation, correct? Just want to make sure as I remember in training the guy I was with always called them out cause he didn't like it but forget the exact reason they were there. thanks.
Saftey hazard, kids palying in the yard can get cut on them. Always called out.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Yep, recommend removal due to safety hazard.
I'll always tell them to break them off sideways verses bending them up and down. If you hit them with a small sledge hammer sideways, they snap. If you hit them up and down, you'll be there for a while. |
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
the reason is because if steel is left exposed it will rust, the rust will expand and spall of the concrete. this is one reason for a lot of the bridge failures, rusting steel reinforcing blowing out the concrete. |
He's simply using his terminology. I knew what he was talking about. Yes, he's referring to the steel pieces that hold the forms together, for the pour. |
| VIDEO--Bowed Basement Wall, Cracks etc | john bubber | Structural Inspections | 75 | 7/21/08 5:25 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Stem Wall Crack | ekartal6 | Structural Inspections | 11 | 10/28/07 4:20 PM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 10:48 AM |
