Just inspected a 2 story house (built in 198
I found in the code book that 2x6 supporting two floors & roof can only span up to 3'11" at most. Does anyone have any comments? |
It is hard to tell exactly from a verbal description but it's been there for twenty some years and, although wood framing members are sized and graded to take a certain amount of loading over time before failure, it seems like one would be able to see sagging, deflection or something showing the beginnings of failure.
Did you see anything like that? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
No. No sagging anywhere. It looks really odd (no pic) to see such small girders for a two story house. I have a code book and nowhere can you use (2) 2x6 past 4'-11". Just wanted to double check myself before submitting my report.
The framing does seem a little light, although it really depends on the specifics. Was the floor bouncy or flexible if you jump on the floor at about where the middle of the spans would be for both the floors and beams? Did the floors squeak? Was the house empty, so there was not a lot of furniture load?
Even if the house was full of furniture and there were no sagging members or bouncy floors, you may want to comment that the framing appears somewhat undersized compared to current construction standards and common local practice (I am assuming you are accustomed to seeing larger framing for similar houses in your area), which would limit the use of heavy furniture and other items like water beds and larger fish tanks for example, and may require supplementary supports which is beyond a home inspection to determine. JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
House was empty and no bouncing or sagging observed. It is only about the size (2x6) of the girders that concerned me. I really like your comment and will use it.
Thanks to all who have replied, Russell |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 4:55 PM |
| SERVARE Online Back UP-Preferred NACHI Pricing | dvondrak | Miscellaneous Discussion for Inspectors | 0 | 6/13/06 9:48 AM |
| Set up to back feed | psmothers | Electrical Inspections | 9 | 6/1/06 9:59 PM |
