How is the wood framing secured to the concrete?
This a Southern Calif. house built in 1960. ![]()
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
David, the only person who can tell you that is the person who did the inspection. What did you see?
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Are you talking about the sill plate?
Pics are small |
What was the general method for a house built back in 1960? |
gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
I see these all the time, can't see any foundation bolts. I think the framers just set the sill with spikes when the concrete was still green. I am sure someone with more knowledge will come in on this. I report no foundation bolts visible, never been called on it and I do worry about it. If you report no bolts and recommend retrofit and you are wrong you would be in a world of trouble
Thanks David |
Gravity.
Perfectly normal given the age. I wouldn't say anything about it. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Whaaat? You claim that no foundation bolts required given 1960's construction? Bolting has been required since 1930's. Chuck |
You never see it on a home here built before before about 1990.
I would assume that on a home built in the 60's the exterior should be bolted. If the sill is obscured, a mirror, camera held at angle or any number of things can help you see (sure you already know that). Many times I can see right through the screens/vents and see bolting on the exterior.
That being said, the interior cripples, grade beams etc are likely not bolted/secured to framing on a home this age. Retrofits are generally not going to call for shearing/bolting/fastening to interior cripples, but ya' never know. Post to beam hardware, metal strapping and similar are not going to be present unless someone installed it after the fact here. The anchor bolt pattern on the exterior sill/sole is also likely sparse compared to today's requirements. I make mention of whether I was able to view bolting or not and what, if anything obscured my view. I will also note that the requirements will be different now than when the home was built, along with other crawlspace observations. You can simply let your customer know your observations.. the interior portion of foundations are not secured/braced and wouldn't have been at the time of construction, but you were/weren't able to view bolting to foundation on exterior and that, you are a generalist and not a foundation specialist. In the view of a foundation specialist (there are many in CA) the home you are inspecting: May benefit from installation of additional hardware/bracing The floor may be out of level beyond what is noticed on a Visual Home Inspection The type of foundation/footing material may be deficient by today's standards ie. Re-inforcement, type (PSI,MIX etc) And so on. This is California, careful what ya say |
Precisely why I said "What did you see?". No one should assume anything about what was or wasn't being done at the time of construction., Write what you see or did not see, what happened or didn't happen. Far too many new inspectors are trying to cover their behinds with what should have been there but in fact they don't know the subject matter well enough. It is a visual inspection of the property on that day. If someone was not there the day the home was built, there is no way to determine what "might" be there. Look, observe, record and move on. If you don't know something, say you don't know. Tap dancing and BS will get your butt into some deep sewage eventually.
Tim you are absolutely right is has been required for years but I have been under several older homes and as much as I try I can't find any, go figure
How could we provide an answer from photographs that fail to show the condition you're asking about? During that era, normal construction would have been an anchor-bolted sill of redwood or (most likely) treated wood (wolmanite) to which floor joists were toenailed. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Bolts were not enforced here until 2006. Before that it was cut nails.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
www.MauiHomeInspections.com |
| Garage floor same level as house a safety concern? | thorn2 | General Inspection Discussion | 11 | 1/25/10 3:33 PM |
| House Built In 2005 | pmagrone | Exterior Inspections | 8 | 6/7/07 3:48 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
