Old 6/19/10, 5:41 PM
Stephen D. Schroetke Stephen D. Schroetke is offline
Location: Serving the Portland and Salem metro areas and the northern Oregon Coast
Default No Foundation Footing, However...
Everything looked great. The house was built in 1989, single story 980 sq. ft. with a six inch foundation. It's a costal climate so frost isn't an issue. There were areas where I could reach under the foundation into the crawl space but there was nothing more than a few settling cracks and eveything looked good in the house. I could not get into the crawlspace but am going back. Code inspections were extremely lax even ten years ago so I'm thinking this was missed/not inspected.
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/19/10, 7:46 PM
Default Re: No Foundation Footing, However...
With a 6" foundation, it sounds like the floor joists would be sitting almost on the ground...
Larry Kage, CMI
231 929 3525
Old 6/21/10, 12:57 PM
Clarification; the foundation was six inches wide. The buyer backed out so I won't be going back to do the crawl, bummer.
Old 6/21/10, 10:51 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Remember, as foundations evolved, so did the advent of footings.
Stone and rubble foundations in old homes have no footings
Old brick foundations likely have no footings.
New pre-cast foundations need no footings. They sit on tamped gravel.
Old 6/22/10, 6:30 AM
Banned
Permanent Wood Foundations (PWF's) need no footings. They sit on tamped gravel or crushed stone.
Old 6/22/10, 9:22 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
Actually the gravel is the footing..... an excellent one at that......depending on the size of the stone, typically 57, it has a compaction rate in the upper 90 percentile.
The other plus for using gravel is that when installed correctly, you will never have a basement leak as the footing itself serves as a natural drain.
The next custom home I build for myself will utilize gravel as footings.
Old 6/23/10, 6:30 AM
Banned
Aw right! Aw Right! Yes, the gravel is the footing. For the PWF, it should be at least 5" thick and extend outwards from the wall at least 2' (I believe; don't have the documents out)
You can still have basement leaks if normal shrinkage cracks develop in the walls, have backfilled with native soils with poor drainage characteristics and have not installed a drainage membrane against the concrete wall. The gravel "footing" is a good addition to the whole water control system.
Missing Foundation Footing jevans Structural Inspections 8 4/13/10 4:56 AM
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 11:45 AM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 11:35 AM
