jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
New home, 2x8 rafters, 16" OC. 12/12 pitch. All homes in the development have no "H" clips in roof decking....is this allowed? Calling all roofing gurus.
They are only needed for 24" OC around here with 7/16 or 15/32 sheathing.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Same here, used on 24" OC trussed roofs.
I normally use 5/8 plywood but still use the H clips. |
Does the stamping on the sheathing call for spacing of 1/8"?? I have seen OSB that does.
Thanks, y'all!
Could it be 5/8" T&G Advanteck where there is no need of H-clips?
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Hi, I hope this information can be of some use to you. I am attaching some articles that have good graphics and photos. First check to see what county you live in, and then see if the ICC codes pertain to your county. 2006 international building code, Chapter 23, construction requirements. 2304.9.4 Other fasteners. Clips, staples, glues and other approved methods of fastening are permitted where approved. 2006 International Residential Code for One and Two Family Dwellings TABLE R804.3 ROOF FRAMING FASTENING SCHEDULE a, b a. Screws shall be applied through the flanges of the truss or ceiling joist or a 54-mil clip angle shall be used with two No. 10screws in each leg. See Section R804.4for additional requirements to resist uplift forces. {Lumber blocking, panel edge clips (one midway between each support, except two equally spaced between supports when span is 48 inches), tongue-and-groove panel edges, or other approved type of edge support.} ICC makes every effort to provide current, accurate code adoption information, but in some cases jurisdictions do not notify ICC of adoptions, amendments or changes to their codes. To ensure you have accurate information, please contact the jurisdiction directly. Mississippi Jurisdiction Batesville
Bay St. Louis
Clinton
DeSoto County
Gulfport
Hancock County
Harrison
Hattiesburg
Jackson
Jackson County
Long Beach
Madison
Magee
McComb
Natchez
Ocean Springs
Olive Branch
Oxford
Pascagoula
Pearl River County
Philadelphia
Picayune
Richland
Ridgeland
Southaven
Vicksburg
West Point
Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
The state of South Carolina has adopted the ICC codes. I have provided some copies of tables, articles, and graphics that you should feel free to use. There are some terrific "technical websites" out there for all of our members to gather information from. South Carolina Statewide
| h clips | nbhi | Structural Inspections | 23 | 5/8/09 11:48 PM |
| Lack of H clips and warranty | poliner | Exterior Inspections | 16 | 2/2/08 5:51 AM |
| HI nightmares in the news and other clips | psiposs | General Inspection Discussion | 1 | 4/18/07 2:17 AM |
| H clips | dmacy | Structural Inspections | 15 | 12/8/06 5:23 PM |
