Home built in 1961, no sill plates, except at the garage foundation. Any thoughts as to why sill plates were not placed and the consequences?
| Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America) |
I've seen it a few times and noted it but I'm sure nothing was done but we don't have the earth movement that some areas have.
I have no idea why someone would omit the sill plate. It seems like more work to leave it out and have to shim each joist. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
One runs into this kind of construction every so often. How is the framing anchored to the foundation? Some don't even have anchors, and just depend on the weight of the house to keep in on the foundation. Not much one can do about it now; it's built.
Not there because it was probably not required..... I have seen many homes w/o sill plates....unless there is a moisture issue then there is nothing to worry about.
I suspect the shims were after the fact.... |
Needs anchoring, needs separation from contact with cement. But those are just code requirements.
Could you see any type of Fasteners installed anywhere? Other than being a framing nightmare and fastening concern as well, really not a big issue being that old. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
No obvious anchors. I realize there is no reasonable repair, and after all of this time the house is not moving. This construction method is one that I do not recall observing on past inspections. I thought the local inspectors would have noted the missing sill plates when the construction plans were submitted or during the permit inspections. Why would a builder attempt to level each joist with slate shims instead of placing the sill plates? This is why I like my job, you never know what will be discovered!
I find a large number of homes from the 60's with the subfloor directly on the foundation. No sill plate. Large beams supporting 2x6 T&G and the ends of the 2x6 rest directly on the foundation. Some have tar paper separate, some don't. Actually nice to inspect since there aren't any joists to scrape your back on.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
That fact that the house has not gone anywhere without anchors speaks for itself................if God wants to blow the thing over.....anchors are not going to hold it down. lol |
I have seen many basements that were built in the 1960's, and never seen any with no box sill plate.
Renovated many buildings with my Father as a kid and never saw no box sill plate. I have no idea what would prompt someone to not install it, considering all the extra labor that it creates building the darn thing. That third picture really bothers me though for the fact that the masonry and brick too good to be 48 years old. The testure and smoothness of the CMU face back 40 years ago when I worked in a block manufacturing plant, did not look that good. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Like everybody else, we need to CYA. I will stay home before a Real Estate agent tells me how he wants his reports. That is unethical in my book. Note what you see and be honest about it and usually it never comes back to haunt you. And Happy Thanksgiving to you and your family. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Same to you Marcel I am cooking the turkey in the Am LOL so if you see on the news of a mass food poisoning event watch for my name lol. I stuff it full of butter and lay bacon over the top , i can feel the old veins closing now.
| Shot-In Sill plate anchors | lfoster | Structural Inspections | 7 | 11/10/09 7:54 PM |
| sill plate bolts | sshipler | Structural Inspections | 6 | 3/12/09 10:47 PM |
| No Sill Plate Under Band Board | Skip Erwin | Structural Inspections | 15 | 4/10/08 3:07 PM |
| Sill plate overhanging stem | dbucknavich | Structural Inspections | 9 | 3/2/08 11:37 PM |
