A typical notched floor girder---notched by a plumber. Is there any way to repair that other than putting a pier directly beneath it?
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
SEveral ways actually. Sistering of the joist is sometimes possible, or strapping with listed hardware. Simpson produces such a strap.
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Jeff, it's not a joist. It's a girder (beam).
My other job is the Building Official for a small town. The "qualified contractor" is the one who cut it. It's up to me to decide if the repair is acceptable.
The same applies to a girder or beam.
In many cases, the load strength can be restored with steel straps or by sistering of the structural member. It really depends on the size/location of the notch and the obstruction placed within the framing member. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I think the writeup should include the need for the builder to supply an engineers document that shows the repair is adequate. Even with regular lumber as opposed to engineered products there are numbers to crunch based on the application, span, wood type, other loads present etc..
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Depending on where the notch is and extent , one can use a flitch plate bolted to the beam.
A jack is installed under the mid-span of the weakened beam and create an upward camber of about 1/4", caution needed to not over camber. A 1/4" thick flitch plate same size in depth of the girder or beam is installed on one side or two sides depending on the stregth required to make the repair. 5/8" 307 bolts are used to bolt through the plates and beam in an alternate pattern and the jack is removed. Size of notch and span affected determines the length of the flitch plate. Adding an extra member on each side of the beam will also work, but the ends of the sisters should land at a lolly column support on each end to be effective. Hope this helps. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I am a home Inspector and showing telling or doing this as a home Inspector ,I feel could lead to Concerns later .
What is a "sealed" repair?
"One or two sides"? How do you determine whether one or two. What is the length of the plate beyond the cut? Can the repair be done when the cut is in the middle 3rd of the girder? Got any photos/illustrations? I'm still struggling with this issue and lean toward: if there is no pier, then an engineer has to design it. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Joe,
Do you have a picture of the girder in question? I am sure a flitch plate would be appropriate however without seeing the notching, its to really make any recommendations. I know in most counties they wouldn't even waste time or energy on it......simply make the builder provide a letter. |
It was a main girder (triple girder I think). Has a 2” plumbing pipe coming through it diagonally. About ¼” of the outside board is cut out for the pipe. As I recall, it’s in the middle 3rd of the girder also. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| San Francisco Appliance, Air Conditioning and Heating Repair | Ron Casey | General Inspection Discussion | 0 | 5/11/08 1:48 PM |
| Phoenix Appliance, Air Conditioning, Heating and Repair | Scott P. Corsley | General Inspection Discussion | 1 | 5/1/08 6:34 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
