Old 7/20/09, 6:21 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Notches
This house was built in 2004. Those are very large notches. Where was the local AHJ?????
Thanks!!!!!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 7/20/09, 6:23 PM
Michael Larson's Avatar
Default Re: Notches
Thanks!!!!!!
Unless I'm missing something I don't see a problem.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 7/20/09, 6:30 PM
Default Re: Notches
I get the same view from Lake Ann.
Larry Kage, CMI
231 929 3525
Old 7/20/09, 8:00 PM
Default Re: Notches
Tell me why?? There is no problem?? I am still learning.
Thanks!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/20/09, 8:03 PM
James F. McKee's Avatar
Default Re: Notches
just what exactly is Your concern Buck?..I'm having trouble seeing a problem also.....maybe it is just the picture...you were there what are you thinking?
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 7/20/09, 8:10 PM
Default Re: Notches
What I see is a notched rim joist.
It's not going to fall down even though it may look a bit odd.
They ran the pvc up the 3-1/2" outside stud wall.
Michael Larson
Hudson, WI
InspectraPro
and
Old 7/20/09, 8:15 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Re: Notches
Is this an interior wall?
I can only assume on your picture several things
Interior wall, perhaps back of a stairwell? There is a wall on the top of this rim joist for the duct work and drain to run in. If there is, the 2x4 plate should span this just fine. Im sure this is a case of the framers saying "... There that ought ta do it...." and the plumber and HVAC guy saying ".... what were they thinking.... now I gotta cut a notch...."
Old 7/20/09, 8:19 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Notches
If that were one of the floor joists, you'd have an issue.
Think about what is carrying the load.
Old 7/20/09, 8:21 PM
Default Re: Notches
With the rigid insulation, it appears to be an exterior wall and you can bet that the complete bottom plate is missing at the heat run.
But, no matter, because the rim joist has continuous bearing and the studs and joists are stacked. What I see there is not a problem.
Larry Kage, CMI
231 929 3525
Old 7/20/09, 8:25 PM
Default Re: Notches
That's what I see from my front porch as well.
Michael Larson
Hudson, WI
InspectraPro
and
Old 7/20/09, 8:30 PM
Default Re: Notches
and from my office as well...
Jim Mckee
Amherst, Ohio
Old 7/20/09, 8:43 PM
Default Re: Notches
There is an interior wall above the notches. There are strange looking uneven areas in the sheet rock. I think I will defer this to a qualified contractor.
Thanks!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/20/09, 8:48 PM
Default Re: Notches
Thanks!!
Need more info Buck.
It doesn't look like an interior wall with the CMU below it.
You were there what else did you see?
Michael Larson
Hudson, WI
InspectraPro
and
Old 7/20/09, 8:58 PM
Default Re: Notches
On the other side is the family room.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 7/20/09, 9:34 PM
Unmoderated Guest
Default Re: Notches
It isn't a structural member, so the notches have no deleterious effect. Not a problem.
Are roof rafter notches allowed rchorey Structural Inspections 25 2/23/09 9:05 PM
Free episode on inspecting hole, notches, and cuts in structural lumber. gromicko Structural Inspections 1 6/30/08 2:36 PM
More PICs. We shot the Holes, Cuts, and Notches show with Paige. gromicko Miscellaneous Discussion for Inspectors 2 3/30/08 7:23 PM
