Old 7/29/10, 5:16 PM
Kenny Rigler Kenny Rigler is offline
Default Old Roof Structure
Hey Guys-
This was on a saltbox style house...not sure on the age. 2x4's on the short side then on the long side the top half was 2x4s then switched over to 2x6s on bottom half. It seems to me that the rafters are mostly supported at the ridge by the 2x8 header beam. Overall span about 24' with one support in the middle. The 2x8 header doubled up in the middle but it's only 1-2x8 on each half.
It seems all a little jimmy-rigged to me but I'd appreciate any advice on what exactly is defective...considering its an old house. Thanks.
Kenny
old-roof-structure-img_5720.jpg   old-roof-structure-img_5850.jpg   old-roof-structure-img_5851.jpg   old-roof-structure-img_5868.jpg   old-roof-structure-img_5864.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/10, 5:28 PM
Default Re: Old Roof Structure
It looks like someone raised 1/2 of the roof without much consideration to changes in loading...
What did you see sag-wise at rafter and ridge?
Larry Kage, CMI
231 929 3525
Old 7/29/10, 5:39 PM
Bob Elliott's Avatar
Non standard alteration of roof structure needs immediate attention and should be examined by appropriate contractor.(safety issue)
Old 7/29/10, 5:49 PM
Dale Duffy's Avatar
Besides the load design at the Gable I wouldn't make an issue of it, especially if there is no sign of failure.
Just because something is not built "Conventionally" does not mean it will not suffice.
This certainly does not look like something that was done last year.
If there is no sag in the Ridge, no doors, window, screwed up, sticking, I doubt I'd mention anything except possibly beef the Gable end, but I have no idea what is below without more photos information.
Looks good from here.
Old 7/29/10, 6:06 PM
When I walked the roof, it felt a little spongy. I'd didn't see any unusual sag in the ridge or rafters. Actually from the exterior, because of the middle support on the long side rafters, there was a slight rise or bump up in the middle of the long slope.
In reference to the windows, which were the old double-hung with mostly broken ropes, they all opened and closed just fine...I couldn't believe it. Here's a few more shots.
old-roof-structure-img_5731.jpg   old-roof-structure-img_5865.jpg   old-roof-structure-img_5868.jpg   old-roof-structure-img_5862.jpg   old-roof-structure-img_5847.jpg
Hays, KS 67601
785-656-0272
Old 7/29/10, 6:19 PM
Dale Duffy's Avatar
Looks even Better to me now Kenny, I wouldn't say a damn thing besides its not framed to today's standards, but that's a given by the age.
Nice lil Love Shaq Ken---
Old 7/29/10, 6:20 PM
Dale Duffy's Avatar
Well why else do you think the addition was put on there!
Hays, KS 67601
785-656-0272
Old 7/29/10, 6:21 PM
Dale Duffy's Avatar
LOL Kenny----
Old 7/29/10, 8:59 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Kenny
From a technical standpoint I would not be worried by the rafters, however the connection at the ridge is a concern. When they widened the house they rotated the original rafter creating that large gap. Now the rafter needs a ledger board for support. I think the connection of the rafter at the top is inadequate. The mid span support could be suspect if the support does not terminate on a support wall. (I can not see the connection between the 2x4 & 2x6 so that area may need more work) Best I advice I can give based on you photos.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 7/29/10, 10:49 PM
Does not mean it will suffice either Dale.
That kind of work will bring issues around here and one of them might be a court suit for not reporting it and recommending a contractor write it off.
Those retired people in your neck of the woods will never make it to the attic so your OK there,but here we are full of Lawyers.
The gap at the top of those rafters is enough of an issue to take notice and have it looked at.
I do not know about you guys but I am not a structural Engineer so CYA.I think that wood is old enough it was cut with a 2 man saw and carved with a draw knife myself.
Old 7/30/10, 12:06 AM
Christopher Currins's Avatar
And they liked doing it.
Christopher Currins
Certified, Licensed
Old 7/30/10, 4:06 AM
Dale Duffy's Avatar
Scaried-Cat--
Old 7/30/10, 7:05 AM
For the age and size of that little house, I would not be too concerned, with that rough sawn lumber and spans.
Seen worse, and were there for years. Can't change the early years of framing other than note it does not meet today's standard and load capacities of today.
Old 7/30/10, 12:41 PM
Larry J. Michael Larry J. Michael is offline
As said above, does not meet today's standards. Wasn't much standard when this house was built. LOL
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Roof Decks and their problems wdecker Miscellaneous Discussion for Inspectors 4 4/29/09 8:26 PM
Truss Uplift rcooke Canadian Inspectors 5 2/26/08 7:43 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Terracotta tile roof structure bthompson1 Structural Inspections 14 9/24/07 10:36 PM
