Old 9/23/08, 4:15 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Opinion requested on patio roof
At what point would you make an issue/comment on a patio or carport roof supported by the rafter tails of the house roof? We rarely get a little snow here, so that is not much of an issue.
Here is my latest one. The attachment itself is good (2 x 6 ledger/facia with hangers). I just worry about the stress (e.g. upward lift on the interior portion) on the rafter tails/trusses.
Old 9/23/08, 4:30 PM
Default Re: Opinion requested on patio roof
"Opinion requested on patio roof"
O.K. We'll get some deck chairs and some lemonade and go up on the roof--and I'll give you an opinion on just about everything.
BTW, I used to live in Eureka.
Old 9/23/08, 4:52 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
The rafters are probably connected to the exterior wall with hurricane clips. I wouldn't consider it a problem if that were the case.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/23/08, 7:12 PM
James F. McKee's Avatar
Ralph ....the only problem i would have with that here is that it is way too flat for snow load....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/23/08, 11:49 PM
jkogel jkogel is offline
You think it looks weak? I think it looks weak. It is typical for an add-on carport, though. I'd recommend a check for a builder's permit or plans, maybe monitoring for signs of stress at the rafter/wall junction and the attachment of the fascia board, and don't let Jae up there until the owner signs a waiver.
John Kogel
www.allsafehome.ca
Old 9/23/08, 11:57 PM
Jeffrey R. Jonas's Avatar
Ralph,
Do you have a closer view photo of this attachment?
Curious...
Jeff
Old 9/24/08, 9:58 AM
rbrady's Avatar
Curious... Jeff
No I don't, but the 2 x 6 facia/ledger was attached to each rafter tail with a steel hanger and the patio roof (2 x 4 ) rafters (?) were attached at the the opposite side of the 2 x 6 at each rafter tail with a hanger. One of the better attachments I've seen.
Old 9/24/08, 1:00 PM
Ralph,
Based upon the information provided...
My curiosity/concern is not so much with the stress at the rafter/wall junction, as I am with the method of connection of the ledger/facia board to the house rafter ends. I have no concern of the 2x4 rafter connection to the ledger. Even though you state that your area has little snow accumulation, it would not take much, with the wrong hangar/connector over time, for downward pressure to cause the entire carport roof to collapse. I see alot of 'crap' work in my area on patios, decks, carports, etc... that has caused me to take a triple look at connections. I am in no way an expert on available connectors and their use, but I cannot think of a single hangar out there that would be appropriate for this connection when considering the transfer of download forces upon it. I browsed through the Simpson/StrongTie products, and find no connectors listed for this connection/load. Maybe I just missed it, dunno. http://www.strongtie.com/products/category_list.html
Also, as obvious as this sounds, whatever hangar method was used, was there a proper fastener in every hole? I find that 90% of the time there is not. Every hangar manufacturer states every hole must have a proper fastener in it.
Hope this was some help to you.
Jeff
Old 9/25/08, 2:51 AM
Attachment 24153
Unless I saw evidence of failure I wouldn't call anything about it. Actually seems better than many.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 9/25/08, 5:19 PM
I am curious how they used a hanger to connect the ledger to the rafter tails. The load on the hanger is in the wrong direction. There would be load transfered through the fasteners, but not through the hanger seat. I suppose one could make a saw cut in the rafter tail and install the hanger with the seat oriented up.
Old 9/25/08, 7:49 PM
Originally Posted by pdickerson View Post
...install the hanger with the seat oriented up.
I've done that...think cantilevered joists/doubled rim joists connection with bearing wall above.
Larry Kage, CMI
231 929 3525
Old 9/25/08, 9:37 PM
rbrady's Avatar
I can see your point. I can't recall how it was done. It seemed OK at the time.
That's why you can't take too many pictures. I have seen many issues in the pictures that I did not see when I was there.
Old 9/25/08, 11:53 PM
Barry Adair's Avatar
Ralph,
How did it feel when you walked it?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/26/08, 12:16 AM
Jeffrey R. Pope's Avatar
This is CA bro We ain't got no hurricanes here
Seriously though, you should always make the client aware of this type of installation. The CBC requires patio covers to be attached to the vertical wall and not the eaves.
When you see this type of installation, you can be sure it was built without the appropriate building-permits.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/26/08, 1:24 AM
rbrady's Avatar
Originally Posted by badair View Post
Ralph,
It felt fine, I was suspicious of the thickness of the plywood though due to some flex. It was covered with flashed down modified bitumen, so I figured the roofers walked it.
Thanks for the input. I didn't think it was technically correct.
Inspecting a metal roof dmacy Exterior Inspections 13 11/3/07 12:08 PM
reason to walk the roof psiposs Exterior Inspections 64 5/13/07 11:55 PM
Cedar Shake Roof Inspection Today gwilcox Exterior Inspections 10 4/1/07 12:14 AM
Roof framing questions? badair Structural Inspections 7 2/22/07 7:03 AM
Moss growing on roof ecox1 Exterior Inspections 45 1/19/06 9:57 PM
