I had a interesting disscussion with the selller on how his attic was framed, and he said it was fine. Of cours he was "a builder" and seemed to know all things great and beyond. I thought it looked as if it needed more support.
The rafter ends only had around 2 inches at best on the bottom and front of the wall. Only toe nails held them in place in the area. This section did have a gable end resing on top. This was the wall between the garage and living space. What are your opinions, and ask questions if needed Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would have to see the whole house for a better answer but at the minimum it looks to be substandard. Probably not going to fail anytime soon but you have to factor in some typical wind and snow regardless of the code region. At least its easy to access for additional framing/bracing.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Unless the seller was my client, I would not discuss any defect with him.
If you suspect that a wall might be unstable you should refer your client to a structural engineer to evaluate and provide a report on it with his seal and letterhead. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
How many toenails and what size nails? What are the rafters bearing on? I think generally speaking, when a seller tells you something you can check it out if it seems important, but not put a whole lot of faith in what they say. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
This is not an ethic question im its a framing question. If I recommended an engineer for this type of stuff I would not stay in business very long.
8 penny and there is no way you could cram 3 in the small area, they were only toe nailed The rafters are being on a structural wall between the garage and living space, and they rest on a 2x4 and then an additional 2x4 was used as a top plate for outward forces. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
If you have a set of the original plans to compare your observations to and find that they were not followed and no written approval for the changes are included with the plans, it is appropriate to advise your client that unapproved modifications were made to an engineer's design. Otherwise, unless you are an engineer and are providing a professional opinion as the integrity of the structure, you are outside the scope of a home inspection as well as your level of expertise. This is particularly true when an AHJ has already inspected and approved the framing as the house was being built. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 3/6/11 at 9:14 AM.. |
My comments noted just this. Evaluation by framer and obtaining plans for reference.
My post was for my own curiosities, and while I am aware of all the unknowns, I figured someone with good framing experience should be able to look and give their opinons. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Sean - I would have to call it out.
I wouldn't refer to the plans or anything of the sort. I would say that the craftsmanship is not of typical practice. The exposed supporting load bearing wall is an unorthodox installation and to ensure the intended structural integrity is present we recommend calling a structual engineer for further evalaution and to determine the exact cost to cure, if any. Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Once you start getting into custom homes or over 3000 sf, things start getting creative. Its hard to follow all the odd designs. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I might have suggested nailing a board across the top of the rafters or adding blocking in between them to keep them from twisting
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
If it is resting on a 2x4 wall then two toe 16d nails need to be on each side of the rafter and each rafter end should have had at least a 3 inch flat cut at the bottom, so the rafter fits flat on top of the wall. I seldom see the two toe nails, let alone the flat cut bottom. Here in Missouri, builders stick only about half or less as many nails as needed. If you ever drive down a neighborhood and see complete roofs sitting in yards or just foundations with only the sill plate still attached, some Missouri Builders built those houses.
A bit difficult to tell from the pictures, but a couple of observations: minimum bearing for a conventional rafter is 1-1/2" on a wood framed bearing wall and 3" on masonry or concrete. So the 2" is fine. Minimum nailing to the top plate is (2) 16d common nails so the 8d are suspect. Can not tell from the picture which way the ceiling joists are running I'm assuming they are not running parallel judging by the seat cut on the rafters on the bearing wall. If that is the case the rafters would be required too have 2"x4" rafter ties or a wall or girder at the ridge. In both cases the rafters are required too have collar ties or ridge straps. Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
2x4 should have been nailed directly above the garage wall top plate with 16d, and the rafters should have been notched to rest on it. That way you resist lateral loads and have full bearing on the 2x4 and you have enough room at the bottom (level) cut of the rafter to get 2- 16d toenails in one side and one in the other. Poor quality framing. 8d nails are a defective installation in this situation. I'd call for correction by a qualified contractor for the fasteners at least.
| cut floor joice | John E. Gibson, #2 | General Inspection Discussion | 16 | 9/25/08 9:45 PM |
