Old 8/19/10, 6:48 PM
John Evans John Evans is offline
Default Opinions on Roof Sheathing
Dark sheathing stains on just one roof slope. Opinions for cause, condensation?
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/19/10, 8:41 PM
James E. Braun, CMI's Avatar
Default Re: Opinions on Roof Sheathing
Could be a combination of several factors:
No tar paper, improper ventilation and the roof not getting enough sun to dry out.
What was the moisture reading?
Old 8/19/10, 8:58 PM
Joe Funderburk, CMI's Avatar
I've seen it associated with poor ventilation (no ventilation).
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/19/10, 9:06 PM
Gary Farnsworth Gary Farnsworth is online now
Hard to tell in these pictures. If the color is a dull gray, it could be that the sheets were out in the elements in a storage yard. How prevelant was the coloring?
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 8/19/10, 9:37 PM
Banned
You may see that kind of staining on north slopes as they don't get the sun to dry them out. But......where did the vapour for condensation come from.......(1) just natural upward winter moist air leakage from the house though ceiling penetrations; (2) outside dryer vent air ending up in the attic (3) outside bathroom eave vent air ending up in the attic
What is the insulated flex pipe in picture 2 serving?? Is it airtight?
Old 8/19/10, 10:41 PM
Marcel Gratton's Avatar
Attachment 38537
Attachment 38538
Attachment 38539
· Improve: We noted that the exhaust duct for the (main floor bathroom) fan discharges the air through the roof soffit. This can promote mould growth in the roof space as a result of air flowing from the soffit into the roof space. It is better to run the exhaust duct through a gable end in the roof space or through a wall or roof. Equip the duct with a backdraft damper provided with weather-stripping and a counterweight or spring to prevent air return (“Clapet Daoust” type of damper or equivalent). Ensure that the exhaust outlet is not blocked, that the backdraft damper is working and closes properly, and that the air is discharged directly to the outside through a sealed, insulated duct. Make certain that duct is the size recommended by the manufacturer and is a short and straight as possible. Seal all leaks.
Cheers,
On The Level Inspection
Gatineau, Québec
Old 8/22/10, 4:38 PM
Mark S. Tyson Mark S. Tyson is offline
Attachment 38537
Attachment 38538
Attachment 38539
If all vents and exhausts are terminated propoerly it appears to be a case of poor attic ventilation.
typically the requirement is to have vents installed in the upper 1/3 of the roof capable of venting 1/150. This can be reduced to 1/300 by the use of vapor barriors and soffit vents
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Old 8/24/10, 7:33 PM
If staining is uniform (that's how it looks in your photos), then it's condensation. If staining were localized it would more likely be leakage. Good chance that Brian's right about only one slope getting enough sun to dry it out.
If a bathroom vent terminates in the soffit and the soffit provides intake air for ventilating the attic, then moist air is being pulled into the attic. That might be enough to cause this kind of problem depending on the average relative humidity and the hourly rate of air exchange in the attic. Also whatever other sources might be putting moisture into the attic. Stack effect can carry quite a bit of moisture up through holes cut in drywall for recessed light fixtures.
Bathroom vents must terminate at the exterior. Not at soffits or beneath roof vents (another common defect).
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Flat roof section wind mit wcampbell2 Florida Inspectors 62 4/25/11 10:07 PM
Newer roof with wet sheathing jbraun General Inspection Discussion 9 3/6/10 7:53 AM
Type of roof sheathing bhartley Structural Inspections 6 6/22/09 9:37 PM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
3/8" plywood roof sheathing kshepard Exterior Inspections 12 8/15/06 7:28 PM
