I'm overwhelmed with work to do, so I'm needing a little help tonight.
I had a 1921 house earlier today that had ceiling vents in all the closets and kitchen that simply opened into the attic, although screens were present. I didn't like it but had never seen it before. What kind of comments are appropriate, any logic behind those comments, recommendations, etc.? Thanks. NACHI 2005 U.S. Member of the Year
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have a concern with food odors in the attic insulation which may attract critters. But then again that would already be an issue since the home is so old.
Mr. Spock says,
Non-standard method of ventilation is present at...this will cause excessive usage of the HVAC systems, if present, wastes utilities and reduces the home's energy efficiency, advise as an upgrade consulting a repair person to remove the vents, seal the holes, and install insulation for greater efficiency and comfort. Logical, based on todays building standards and insulation marketers. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Attic fan in garage ceiling | cowen | Exterior Inspections | 10 | 8/20/11 5:53 AM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
| Hub vents in attic | mmorgan | Plumbing Inspections | 10 | 5/15/06 7:14 AM |
