Old 6/22/11, 6:57 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default This passes in the land of fruit and nuts
High (low) lights:
Gun nails into all the Simpson brackets (hangers, caps, etc.). Don't they make a specific nail for that?
Bolts a tad bit small for the post anchors at the base. Laughable.
Lateral bracing nailed, no bolts.
Retaining(gulp) wall and what's that? The deck foundation sliding along with it.
So out on the inspection yesterday I was questioning the structure and the listing agent was quick to produce a permit card. Permits were pulled for this? Sure enough... just called the City because I didn't believe it...it passed final first time through.
All I can say is WTF. I'm still going to recommend a review by a structural engineer for the sliding hillside AND the piss poor construction of the deck.
passes-land-fruit-and-nuts-deck1.jpg   passes-land-fruit-and-nuts-dscn1713.jpg   passes-land-fruit-and-nuts-dscn1698.jpg   passes-land-fruit-and-nuts-dscn1696.jpg
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/22/11, 7:12 PM
Tim Spargo's Avatar
Default Re: This passes in the land of fruit and nuts
That deck had permits? I betcha there may have been a deck built with a permit, but it wasn't *THAT* deck.. a rebuild?
Other things wrong with the CB... tell them the 1/2" hole is a good pilot hole for the correct sized one. CB should have 3" cover.. doubt it's there, even though that's PT, most plans for patio/deck posts will req 1" gap from crete. The post/beam connector used may be OK for interior post to beam/girder, but I've never seen one allowed on outer perimeter. And yes.. lags should have been bolted with min 3/8 lags or 1/4" SDS with min penetrations.
Then again.. you never know. Jot down whatcha got and go from there
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 6/22/11, 7:53 PM
a rebuild?
Good chance! I can't come up with another explanation. Not even a greenie inspector would miss these. Couple more pics attached. The post at the upper right corner bears down on the exterior wall - couldn't get in to see the connection in the attic.
This deck was supposed to be built per IB211, which is here:
http://www.sandiego.gov/development-...etin/ib211.pdf
However, this more appropriately falls under their IB206 for a patio cover, IMO due to the height.
http://www.sandiego.gov/development-...etin/ib206.pdf
And THAT requires the use of 6x6 posts for a floor height of 8' - 10'.
passes-land-fruit-and-nuts-dscn1699.jpg   passes-land-fruit-and-nuts-dscn1700.jpg
Darin Redding, CPI
Facebook Like
619-663-8740
