Send me pictures of nasty-looking notches and drilled holes in floor joists and wall studs that were deemed defects, and I'll try to put them in an up-coming instructional/training video at www.nachi.tv. Your name shall appear at the ending credits of the video if your picture is used.
ben@nachi.tv Thank you. |
Heres a picture of a band/rim joist being cut to accomadate the tub piping.
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Joe Skrypka MBA RHI CMI The Home Inspection Guy Inc. Hamilton, Ontario Canada Membership No. NACHI050062193 |
Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
Why plumbers shouldn't be allowed to OWN Sawzalls! If they own 'em, they'll use 'em!!! That picture showed 2 joists fully cut for a 1.5 -2 inch pipe. Plumber obviously only owned one tool and it wasn't a 90 degree angle drill! Saw one 18 months ago in a new house construction for an aquaintance who works the contractors section at local building supplies dealer. I was installing an HRV system: For 3" drain for a water closet, they cut out 3 joists. Phoned owner and told him to call the local AHJ to get someone out asap before the plumber got any farther. The bad joke of it was: The plumber is a part timer.......his regular job.....a butcher!!!!! I swear.....the truth!!! Last edited by Brian A. MacNeish; 3/22/08 at 9:04 AM.. |
Thanks guys.
Use these if you can. I guess the light was so everyone could see their fine workmanship. It didn't work.
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Still one of my favs. Let me know if you need a Hi res version.
Staircase strap support
Other side of staircase strap Engineer redesigned a repair before this was enclosed Waste in undersized 2x4 wall no top plate and that metal was some 25-26 ga roof metal and only on this side Engineer redesigned a repair before this was enclosed Missed layout so obvious this blind inspector found it have fun ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 12:56 AM.. |
How bout deck with no ledger board and joists attached with only 2 "TICOs" into 1/2" cedar siding?
How bout split rails and skinned trees for support posts?
| Pictures Needed | kgoff | Miscellaneous Discussion for Inspectors | 1 | 4/16/07 7:53 PM |
| Inspector Wendy's Home Inspections-Service Areas | wforsyth | Miscellaneous Discussion for Inspectors | 57 | 9/5/06 11:10 PM |
