I have never seen a pier that was made of both brick and cinder block in this area. Everything is either all brick or all cinder block. Every pier under this 2 story house was like this. Is this common in other areas of the country?
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
Those folks are the most creative at using whatever is available to do whatever it is they want to do at any time they want to do it, usually right after a hurricane, or after a hurricane. I sometimes find similar stuff out in the beach communities, but they weren't designed by any engineer. NACHI 2005 U.S. Member of the Year
No brick and cinder block around here, unless its a mobile home..Mainly conrete piers and wood columns, or metal jacks.
Anything is possible; dependant of course on the skills of the builder. Your picture does not seem to indicate the pier is in distress.
I've seen it and don't think there's anything wrong with it if there is a footing.
There were footers under the piers and all of them were in shape, I guess they were trying to save a dollar by using some cinder blocks and not all bricks.
I have seen everything from concrete filled paint cans to cypress stumps. As thing go that pier would not concern me greatly. It appears to be doing the intented job and been in place a very long time. Often we find someone has installed concrete blocks with the voids positioned horizontally and then they wonder why they crushed.
I wasn't aware of those type of red bricks being approved for structural support.
We have thousands of home here with nothing BUT piers made from red clay bricks. Many of the very old homes have problems with them crumbling apart because they would often use beach sand (because it was free and plentiful) instead of builders sand for the mortar. You can rub mortar joints out with your fingernail. Over time the salts and minerals leach out and the mortar joints are little more than sand stone.
Hi to all,
As others have said I se nothing much wrong with that pier, but I do wonder how they got them all so nice and level without any shimming? Unlike this one from my inspection yesterday!! Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry you always come up with the good ones. ha. ha.
Brick on top of the concrete masonry unit is actually better than just CMU, in this case due the density capacity of the brick transfers the weight to the weak link in this case the CMU. Not having shims would explain that it was set to elevation before the framing, which would mean, it has been there for a long time. Looks good to me. Marcel |
Beats the heck out of wood shims that compress with load and time.
Wood, and wood shims, actually are very versatile and last quite a long time under load, depending on conditions. Obviously, something in a moisture environment or eaten up by WDP&O won't perform the appropriate job. NACHI 2005 U.S. Member of the Year
| Helical Piers vs Push Piers | rnewland | Structural Inspections | 23 | 12/3/07 9:50 PM |
| Piers / Beam | jhagarty | Structural Inspections | 8 | 4/25/07 1:04 AM |
| Wood plates/shims on masonry piers supporting girder? | rmc3inspection | Structural Inspections | 6 | 7/11/06 7:49 PM |
| Piers | psmothers | Structural Inspections | 1 | 5/27/06 12:38 AM |
| What's the point of these piers? | jfunderburk | Structural Inspections | 25 | 3/25/06 8:39 AM |
