Does this look right?
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 4:34 PM.. |
Steel shims are perfered in Colorado. I would suggest those everywhere. Don't compress with time or heaver load.
Is that a Cinder Block with fill and rebar looks like it. |
Excessive squash blocks............. Hope all is well in PA. Joe..!! Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Joe,
are you questioning the support or the beam, or both? 2x's on the flat glued together? maybe its ok because there is so many of them. CJ |
Gluelam beam is fine.
It is the 2x PTL shims with a piece of OSB that I was wondering about. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Hi Joe,
I would be tempted to call out the OSB shim, as we know it has little to no compresive strength, plus in a damp location within a crawl space it will very quickly take on the charictaristics of wet cardboard, that Gluelam will end up with little or no support. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Hi guys,
I do know what a gluelam is, that looks like a homemade beam. I have never seen a gluelam with glue oozing out like that. ?? |
That would be a "homemade" glue-lam, certainly not something a factory would produce. The OSB shims are the biggest concern (IMHO).
I might mention that the support system is "non-standard" (at least what you have pictured), and suggest they get a "second opinion" from a qualified contractor. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
As Dale said, mention that it's not correctly built, but I wouldn't make a big deal out of it either. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Helical Piers vs Push Piers | rnewland | Structural Inspections | 23 | 12/3/07 8:50 PM |
| Crack in Support Beam | Berry T. Wilson | Structural Inspections | 6 | 5/26/07 3:15 PM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 10:40 PM |
| Steel beam bearing 1 1/2" | scosta | Structural Inspections | 17 | 6/12/06 9:01 PM |
