Whats the way to determine? I have a home inspection where they
get snow, I was told by a realtor that the roof's have to have a minimum pitch... David |
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Take a 2' level up with you, put one end of the level on the pitch of the roof, level it and measure from the opposite end to the roof surface. Divide that measurement by 2 and you will have the pitch expressed in the formula of
x in 12. |
There is no minimum pitch, If the pitch is below 4 in 12 it is said to be low slope. These roofs must use a roofing cover designed to accommodate the lower pitch. In the same line of thought there is now such thing as a flat roof. All roofs have some slope to them or the water will not drain.
Larry |
There is no minimum roof slope I am aware of other than roofing manufacturer's requirements. But in mountain regions and other heavy snow load areas roof slope becomes more important. The lower the roof slope, the higher the loading on the roof structure.
Talk to inspectors and builders in your area to find out what minimum roof slope (e.g. 6:12) is considered "good practice" for conventional framing in your region. And if you see a lower slope roof in a high snow load area look closely for sagging ridges, roof dishing, bowing outer walls, and other visual indications of a potential problem. JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
"Whats the way to determine?"
I use one of these, usually visually from the ground by aliening with the rake: http://tinyurl.com/yuoufx The the version I got at Home Depot displays out in both degrees and x/12, and can also be used as a short level and to to provide a quick check for out-of-square doors and windows. |
Try this.
Like Larry said.
Roof CleaningGuttersAwning CleaningHouse WashingFence & DecksSurface Determining Your Roof's Slope or Pitch The slope of your roof is determined by the vertical rise in inches for every horizontal twelve inch (12") length (called the "run"). It is expressed with the rise mentioned first and the run mentioned second. For instance, if your roof has a four inch (4") rise for every horizontal foot, then it has a "4 in 12" slope (or pitch). ![]() ![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Pitch & Gravel Roof Inspection | maitai11 | Exterior Inspections | 4 | 1/25/07 9:43 PM |
