Old 4/21/08, 10:06 PM
Rick A. Harrington's Avatar
Rick A. Harrington Rick A. Harrington is offline
Default Plates at rim joists with attached straps
Just wondering if anyone has information on this device. There are 6x6 inch plates attached at the rim joist around the basement. Unfortunately the straps are covered by the water management system and I can't see where they go.
I can move the straps. not much tension.
Any help would be appreciated... been search in the internet.
plates-rim-joists-attached-straps-dsc02544.jpg   plates-rim-joists-attached-straps-dsc02561.jpg
Rick A. Harrington
Patch Independent Home Inspections, LLC
Serving Columbus and Central Ohio
Certified Specialist - Infrared Residential Inspections Advanced
Certified Level 1 Thermographer
Certified Mold Inspector
State of Ohio Licensed Radon Tester
http://www.patchhomeinspections.com
http://www.centralohiohomeinspector.com
http://www.columbusohiohomeinspector.com
http://www.thermalimagescanning.com
Old 4/22/08, 2:28 PM
Peter Doane's Avatar
Default Re: Plates at rim joists with attached straps
Never seen this. Not too many basement out this way. Possibly a support/ hold for an item (behind wall) for the water management system?? Since you stated that the straps have no tension, I wouldn't imagine they have any structural significance, plus its a cloth, nylon or fiber strap material which further leads me to believe its a light supportive hold. Whats on the outside of the home at this location? Just curious.
*Call a local company that does this sort of install and ask them if you can send them an email photo for possible identification of a system component.
Peter Doane
NACHI ID# 05120681
Old 4/22/08, 9:01 PM
Your right Peter, I can't see any structural significance here either.
I blew it up 400% and it is just a plate with a D-ring and a double nylon strap going down behind the drywall, or whatever it is.
I would still be curious as to what it was for.
Marcel
Old 4/23/08, 1:38 AM
Attachment points for a crane?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/25/08, 7:45 AM
I still have not found out why these are installed at 6 foot intervals on the house built in the 50's with block wall cracks. A water control company has been in and added the plastic coated walls and drainage to control the water. Too bad they never repair the reason the water is getting through. Only manage the symtons, not the cause.
I'm still checking around.
Rick A. Harrington
Old 4/25/08, 1:44 PM
David C. Macy's Avatar
Do you know what company did the waterproofing?
If you find out and they have a website maybe they would have some information or you could call them.
I have seen the strips or sheets that they place on the walls. Some are painted on and some are in strip form.
Maybe the one you show is an addition support for the strips.
I would think the epoxy or whatever the material is they would not need those anchors.
That is definetly one I have not seen.
Unfamiliar newer floor structure -- span too long for engineered joists? fbartlo Structural Inspections 8 2/10/08 11:11 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
floor joists Kyra Bloom Interior Inspections 19 11/23/07 10:38 AM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Cantilevered Joists Steven Brewster Structural Inspections 13 5/9/06 7:32 PM
