Old 1/28/08, 12:49 AM
Mark Nicholet's Avatar
Mark Nicholet Mark Nicholet is offline
Please Note: Mark Nicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Plumbing in bearing wall
Hello, My name is Mark and I am currently an undergrad of Carson Dunlop home inspections course. I took these pictures today of a house under construction. They are pictures of plumbing in a bearing wall. The plumbing has completely cut the top and bottom plate of this bearing wall. I confirmed that this wall was supported in the crawl by a bearing wall to foundation. As you can see in the pics the floor joists (above) are bearing onto this wall. I think this is a significant structural issue. I wanted to run these pics by everyone and get their opinion. Thank you.
plumbing-bearing-wall-200801271638000.jpg   plumbing-bearing-wall-200801271639000.jpg   plumbing-bearing-wall-200801271639001.jpg   plumbing-bearing-wall-200801271639002.jpg
Old 1/28/08, 12:54 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: Plumbing in bearing wall
What Bearing Wall??
This plumber really had it in for the carpenter.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 1/28/08, 3:17 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yikes
Ah ...on second thought nobody will no ounce the drywall go's up.
Old 1/28/08, 7:37 AM
David P. Valley's Avatar
That's it...Where's the damn architect when you need them?
A simple lack of planning and coordination.
Old 1/28/08, 8:36 AM
They do it everytime.
What is wrong with a 2" x 6" wall?
Reinforce it now with,
http://www.tamlyn.com/index_files/PlatesandBrackets.htm
http://www.strongtie.com/ftp/fliers/F-REPRPROTECT07.pdf
Marcel
Old 1/28/08, 8:52 AM
Michael Larson's Avatar
Every time?
Nothing
Thanks for the lknks Marcel.
I'm sure those plumbers will be back tomorrow to put the strongties on on.
Old 1/28/08, 8:53 AM
Unmoderated Guest
Marcel has the answer, and that reinforcement should be made a part of the plumber's contract by the General Contractor. It has very little to do with the architect, who is not responsible for the techniques of construction; that is always the responsibility of the general contractor. We don't know, in fact, if someone is planning to install the reinforcing plates that Marcel refers to, or not. It isn't a critical issue until it's about to be covered up without reinforcing.
You haven't lived until you've seen one or two floor joists completely cut by a plumber and left hanging with no support. There ain't no reinforcing plates available to deal with that.
Old 1/28/08, 8:59 AM
Banned
Mark:
In our area of NS, the AHJ would want to see metal straps on both sides of the top plate to maintian the tensile strenghth of the bearing wall as it ties the exterior walls (wind loads) to other major framing. Plus another stud by the pipe to pick up the load from floating end of the cut doubled top plate.
Quite a simple fix. Used to have to do it fairly often when we were installing HRV's/ERV's with 4" individual room supplies and wall stack (3.25" x 10/12").
Old 1/28/08, 9:05 AM
Banned
Originally Posted by jgilleland
What Bearing Wall??
They all do!!!!
Last year I installed an HRV in the retirement home for a gent who works the contractors' counter of the local building supplies store. He hired a butcher (no crap.....see him every week at the local grocery chain store) who does plumbing on the side. I called the owner one day to tell him to call the local inspector about a fix for the 4 substantially cut joists for the horizontal run that was part of the 3" soil/waste run from the upper level bathroom. A butcher he was!!!
Old 1/28/08, 12:41 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Marcel
Thanks Marcel.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 6:25 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
what a non weight bearing wall (posted by clarence kluesner) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 10/25/07 9:55 PM
Bearing wall support modifications bwooddell Structural Inspections 1 5/18/07 12:44 PM
