Is not overlapping the poly at the bottom of the grade beam correct depending on what part of the country you are? I had someone from the country of Dallas
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Water entry at bottom of vinyl-sided chimneys that jut out | fbartlo | Exterior Inspections | 10 | 8/11/07 3:18 PM |
| Crack in Support Beam | Berry T. Wilson | Structural Inspections | 6 | 5/26/07 3:15 PM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 10:40 PM |
| Steel beam bearing 1 1/2" | scosta | Structural Inspections | 17 | 6/12/06 9:01 PM |
