Every see house wrap used? What do you say about it? Is there anything that specifies the type of material that should be used as flashing?
| Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America) |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
You want something non-permeable, Joe, like aluminum, copper, lead, galvanized, PVC, etc.
http://www2.dupont.com/Tyvek_Weather..._builders.html "12. Can DuPont™ Tyvek® be used as flashing? DuPont™ Tyvek® weather resistive barriers have not been tested or approved as a flashing material. DuPont introduced the DuPont™ Flashing System that provides comprehensive protection from water leaks. It is designed to help direct water to the building exterior instead of trapping it inside the wall system and causing water damage." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
It looks like they offer a few products for various uses: http://www2.dupont.com/Tyvek_Weather...g_systems.html InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
When the manufacturers of Tyvek provide housewrap that is "approved corrosion-resistant flashing", it can be used.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Builders / framers erroneously use it all the time........especially around synthetic stucco and similar applications.
| Proper porch flashing? | jfunderburk | Structural Inspections | 1 | 9/24/08 2:18 PM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 3:00 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 3:05 PM |
| Deck flashing question | scosta | Exterior Inspections | 7 | 10/16/07 12:21 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
