Old 6/3/09, 10:13 PM
Joe Funderburk, CMI's Avatar
Default Porch support posts
Anyone see an issue here? House is 16 years old. Screened and roofed porch was probably once a deck. Support posts showed no evidence of fastener attachment to the beams. Ledger was bolted well to the house so movement is unlikely.
(The beam perpendicular to the ledger was not typical also.)
porch-support-posts-060309-005.jpg porch-support-posts-060309-024.jpg porch-support-posts-060309-025.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America)
Old 6/3/09, 10:26 PM
Jeffrey R. Jonas's Avatar
Default Re: Porch support posts
Joe,
It appears the ledger is fastened over the brick veneer. If so, this is a no-no.
Old 6/3/09, 10:30 PM
Michael Larson's Avatar
Same guy built this one.
Michael Larson
Hudson, WI
[/I]
Old 6/3/09, 11:50 PM
Thanks guys. Here's what I came up with.
"There are components of the wood deck that are structurally unsound. The posts were not fastened to the beam in any way we could observe. Through bolts or approved brackets are the recommended method. We can elaborate on this issue, but the entire deck should be evaluated by a competent and licensed contractor and serviced accordingly."
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/4/09, 6:07 AM
John Evans John Evans is offline
As mentioned, attaching a ledger board to brick veneer is not recommended. It is hard to see, but there appears to be some empty nailing holes in the joist hangers.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 6/4/09, 7:24 AM
It looks like the ledger to house bolts are high enough to catch the rim joist in the pictures.
Joist ends, beam ends and post ends without mechanical attachment should be noted with repairs as needed.
Larry Kage, CMI
231 929 3525
Old 6/4/09, 7:38 AM
True but in this case there is very little shear load at the ledger board due to the intermediate posts.
This deck could easily be made free standing by adding posts near the ledger board and eliminating that issue.
Michael Larson
Hudson, WI
[/I]
Old 6/4/09, 9:24 AM
Ledger was bolted through the rim joist at the house. I think the issue alluded to was that the brick may shear off the bolts.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/4/09, 9:25 AM
Good eye. Most of the hangers only had 2 screws per side. I wrote that up also.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/4/09, 9:12 PM
I'm not following you.
You mean if the deck sagged the brick would shear off the bolts?
If so, it was not attached properly.
Larry Kage, CMI
231 929 3525
Old 6/4/09, 9:25 PM
That is the thinking, I believe. Sheer forces may break the bolts if the house and/or deck settles.
On brick veneer homes, another line of thought is that if there is any settlement in the deck, it will crack the brick veneer. Best to have a stand-alone deck with a 100% brick veneer home.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/5/09, 11:42 AM
Isn't that a couple of toenails through the joist into the top of the post? If so... not great, but not going anywhere.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 6/5/09, 1:14 PM
Bruce A. King's Avatar
Less than code decks are the norm, I have found just one deck in over 4 years that was completely built correctly. It was on a tore up foreclosure, mold infested house. The reason that the deck was correct appeared to be due to the previous use of the home (group home of some sort) and a permit was pulled for the deck. It even had grippable handrails.
Reporting on deck construction methods can range from a simple, unhelpful, "its built wrong" to trying to explain the issues with pictures etc. as Joe has done.
Both methods have possible implications and we as home inspectors have to struggle to find a good way to report deck issues. I have tweaked and tweaked my deck reporting and will continue to do so because most have their own unique issues, some of which while "wrong" are not really going to fail.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Leaning Deck Posts thance Exterior Inspections 12 2/2/08 6:37 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Heavy timber posts and support beam hziegenbein Structural Inspections 4 9/24/07 8:22 PM
